just dont let them grind itKnightEngines wrote: ↑Wed Aug 12, 2020 3:15 am Tighe cams in Australia will scratch make you a cam blank for pretty much anything, they'll do 1 off's no problem.
Welded Camshafts for regrinding
Re: Welded Camshafts for regrinding
I believe the woman you talked to might be one of the owners or head manager....She was indifferent to me and I get along good with reps on the phone. Maybe because it's vintage bike cams that she was not familar with...
Yeah, probably worth mentioning that!benno318 wrote: ↑Wed Aug 12, 2020 7:52 amjust dont let them grind itKnightEngines wrote: ↑Wed Aug 12, 2020 3:15 am Tighe cams in Australia will scratch make you a cam blank for pretty much anything, they'll do 1 off's no problem.
They make me Holden 6 steel roller blanks - which I then get Mal at camtech to grind for me!
Thank you for all the advise. It sounds like there are some options after all.
Is there any warehouse sources around for old cam blanks? I took my last one off the shelf. It has a part number on the box ep-22 and that number is also cast into the core. On the other side it is cast CWC. I think they were made in the USA, not japan. Just thinking maybe someone has some dusty old stock somewhere.
EP-22 is the part#(73-79 1200cc Civic 4 cyl), from Engine Power Components in Grand Haven MI.donforeman wrote: ↑Mon Aug 17, 2020 11:44 am Is there any warehouse sources around for old cam blanks? I took my last one off the shelf. It has a part number on the box ep-22 and that number is also cast into the core. On the other side it is cast CWC. I think they were made in the USA, not japan. Just thinking maybe someone has some dusty old stock somewhere.
No Warehouse would carry an unground cam core. I would check with older cam companies, like Isky.
You could also try EPC. Maybe they have a pile of them, stuck in a corner somewhere.
Since your Civic is more recent and much larger production, It is to be hoped you have better luck than I did. I visited Iskenderian and with Ed's permission searched the dusty shelves. They had no unused Studebaker or Packard cam cores. I called EPC and they said they cast to production orders. At their volume, nothing can sit. It's ordered, cast, ground and shipped ASAP.CamKing wrote: ↑Mon Aug 17, 2020 12:14 pmEP-22 is the part#(73-79 1200cc Civic 4 cyl), from Engine Power Components in Grand Haven MI.donforeman wrote: ↑Mon Aug 17, 2020 11:44 am Is there any warehouse sources around for old cam blanks? I took my last one off the shelf. It has a part number on the box ep-22 and that number is also cast into the core. On the other side it is cast CWC. I think they were made in the USA, not japan. Just thinking maybe someone has some dusty old stock somewhere.
Thank you for the help. I have a lot of ground cores. I was just trying to eliminate the weld up job to get a factory base circle. Isky is out of blanks ground and unground. Checking with Web cams now they may have one.
For some of these "unique" applications, try Camcraft in Canton, NC. Great folks to deal with. Regards, Chase
I have found about 8 people so far that may be interested in a new blank so far. I have done parts runs before it takes a little while to get the word out and people interested as the market is small. In January we had 55 adjustable timing gears made that turned out really nice. One person brought up that if the cam blank is billet instead of cast, how will that affect the oil pump and distributor gears? If those have to be remade, the run is not looking good.
Are the stock gears that ride against the gears on the cam, iron, steel, or bronze ?donforeman wrote: ↑Mon Sep 07, 2020 2:48 pm I have found about 8 people so far that may be interested in a new blank so far. I have done parts runs before it takes a little while to get the word out and people interested as the market is small. In January we had 55 adjustable timing gears made that turned out really nice. One person brought up that if the cam blank is billet instead of cast, how will that affect the oil pump and distributor gears? If those have to be remade, the run is not looking good.
Thanks for the fast reply. I am not sure, the original honda cam for sure is cast. The aftermarket cast blank from EPC has the complaint though that they are softer than honda cam and do wear out gears sooner with street use. Thats why Colt cams and a few other places say they did regrinds even when the blanks were easier to find. On the race track they seem to last. The gears that ride on the cam look like steel. It could be cast and machined though. No rough casting anywhere on the gears though.
I got this from Tighe a few minutes ago, I emailed them because we are stuck at 8 for the moment.KnightEngines wrote: ↑Wed Aug 12, 2020 3:15 am Tighe cams in Australia will scratch make you a cam blank for pretty much anything, they'll do 1 off's no problem.
Yes we Know the engine and we have had cores for them in the Past. The picture is a US made casting. We can Make low volume runs of Billets But do not have the gear cutters to cut the gears on the Honda have looked it that before. The economics is not worth the small volume. The gear hobs are $2500.00 before we even begin.
Sorry Regards
Dean
Someone mentioned that the gears on the honda camshaft are removable if you try hard enough. I guess it takes both heat and a lot of force in the press. It does help explain why the gears do not wear like the cast lobes though and the complaints of the aftermarket cast cores being too soft. Seems that the gears could possibly be transferred to a new semi finished blank if needed.
I have two of them cars in my junkyard if you need any parts, they are rusty but low mileagedonforeman wrote: ↑Mon Aug 10, 2020 9:22 am I have 70s 1.2L Civic I am redoing for SCCA vintage racing. It's not really that fast with only about 100 hp at the wheels, but it does OK in its class with the Mg Midgets and Sprites. Speed parts used to be available, but now are getting really hard to find. I had two new semi machined cast cam blanks i purchased from King Motorsports in the 90s. I sent one to Schneider cams a few years ago and spent about 30 minutes on the phone with the tech guy specifically telling him what I wanted and this was not a street car. They ground a very mild street grind into my new cam blank being lazy and not paying attention to my request, basically ruining the blank for my use. So that leaves me with just one cam blank left to try again. Not sure I want to risk that one at this point. Some people say that the original cams can be welded up and reground others say it's not a great alternative finding a new blank. What is the scoop on welding cast cams to end up with a usable core for grinding? I keep looking for new blanks but so far none in anyone's stock I can find. If the oem cam is reground without welding and the base circle reduced the rockers get all messed up geometry wise so really I don't want to do that either.
Pro question poster.
