Throttle response and EFI
SpeierRacingHeads
Post by SpeierRacingHeads »
I think it's pretty good. The induction worked out well. Has some scat from off idle.
https://www.facebook.com/chad.speier/vi ... 577500552/
Speier Racing Heads
Chad Speier
785-623-0963
RevTheory
Re: Throttle response and EFI
Post by RevTheory »
Definitely a snappy dude.
bob460
Post by bob460 »
FuelieNova
Post by FuelieNova »
Who's EFI controller are you using?
Any details on the build?
Tom
SpeierRacingHeads
FuelieNova wrote: Mon Sep 14, 2020 5:11 pm Who's EFI controller are you using?
Tom
Holley HP
379 with 10-1, 231/235 cam, SRH 205cc CNC heads on 91 octane.
Speier Racing Heads
Chad Speier
785-623-0963
ptuomov
Post by ptuomov »
Is this a plenum manifold with throttle body injection?
If it’s a plenum manifold with a throttle body injection, why wouldn’t it be better to use the same number of throttles and injectors in an independent throttle body system with the throttle close to the port and injector spraying into the runner?
SpeierRacingHeads
ptuomov wrote: Tue Sep 15, 2020 9:08 am Is this a plenum manifold with throttle body injection?
The main reason I did this is because I wanted to maintain the Camaro air inlet system.
Speier Racing Heads
Chad Speier
785-623-0963
ptuomov
Post by ptuomov »
I can see that the air filter etc would be time consuming to refabricate. I have no objections with a single throttle plenum EFI manifold with port injectors. That’s what I got!
I was more commenting on the EFI university Holley sniper system that has eight throttles but looks like a plenum manifold with throttle body injection.
bob460
Post by bob460 »
ptuomov wrote: Tue Sep 15, 2020 11:17 am I can see that the air filter etc would be time consuming to refabricate. I have no objections with a single throttle plenum EFI manifold with port injectors. That’s what I got!
400ci......1200+hp.........10,000+rpm.......nothing more to say!!
https://scontent.fmel6-1.fna.fbcdn.net/ ... e=5F85E6EA
ptuomov
Post by ptuomov »
bob460 wrote: Tue Sep 15, 2020 7:57 pm
If you only drive the car at full throttle, obviously most of this stuff is moot. The location of the throttle or throttles doesn’t matter. However, since the thread title was throttle response, I think it’s relevant how the engine cruises at part throttle without surging and then takes off without a bog when floored.
SpeierRacingHeads
Yes, the EFI University sniper is pretty killer.
I flowed the stock air lid before/after.
Stock form with and without filters like 725cfm
Reworked with and without filters like 1280cfm
Speier Racing Heads
Chad Speier
785-623-0963
