using SF Air Turbine to determine Header problems
Re: using SF Air Turbine to determine Header problems
mostly my fault
i never yet made a .CHM or .PDF Help file
but will definetly create a lot of YouTube Videos , animated .GIFs, a CHM and PDF Help files for newer version 5.0
no use creating anything now for v4.50 version when v5.0 is going to be completely different Screens
you might look at these new Pics i posted for more insight how to use v4.50
viewtopic.php?p=876301#p876301
just go thru some of the 48 included example files , look in the custom NotePad screen ,
look how i did things to make PipeMax v4.50 correlate to Dyno Sheets + Flowbench Data
Larry,
Just out of curiosity, how do you determine port centerlines?
i use Scotch 3M 218 Fine Line Tape to measure Roof and Floor Lengths + a Fine Point Sharpie to mark location across the tape
Cylinder Head's Intake or Exhaust Port CenterLine Length in Inches
( the Length thru the centerline of the Port , from Port Entry/Exit -to- Seat LapLine )
then :
Example=> Roof= 4.200 + Floor= 2.200 Total= (6.400 / 2) = 3.200 Port CenterLine Length
and
Average_CSA = Port_Volume_CC / (Port_CenterLine_Length * 16.387)
and
CSA Velocity FPS = ( Intake Port CFM * Intake Port CenterLine Length * 39.3289536 ) / Intake Port Volume CC
Code: Select all
--- Examples of Cylinder Head Intake and Exhaust Port CenterLine Lengths ---
--- Chevy Small Block Heads ---
Inches Inches Millimeters Millimeters ---------- Cylinder Head Description ----------
Int=5.299 Exh=2.796 Int=134.6 Exh=71.02 GM #3917291 SBC out-the-box shape 1.940-1.500
Int=5.339 Exh=2.818 Int=135.6 Exh=71.58 GM #3890462 SBC out-the-box shape 1.940-1.500
Int=5.168 Exh=2.800 Int=131.3 Exh=71.12 GM #041x SBC Ported in SuperStock shape 1.940-1.500
Int=5.315 Exh=2.850 Int=135.0 Exh=72.39 GM #441 SBC Bowl-Ported & Port Matched shape 2.020-1.600
Int=5.195 Exh=2.785 Int=132.0 Exh=70.74 GM #292 SBC ported 215CC shape
Int=5.410 Exh=0.000 Int=137.4 Exh=0.000 GM #034 SBC cast-iron Bowtie 225CC shape
Int=5.453 Exh=3.023 Int=138.5 Exh=76.78 GM #10207643 LT-1 SBC aluminum in Out-the-Box shape
Int=5.415 Exh=2.978 Int=137.5 Exh=75.64 GM #10207643 LT-1 SBC aluminum in Ported shape
Int=5.432 Exh=2.780 Int=138.0 Exh=70.61 GM #14014416 1.840/1.500
Int=5.490 Exh=3.396 Int=139.5 Exh=86.26 GM #10134363 2.180/1.600 18 degree SBC
Int=5.758 Exh=3.623 Int=146.3 Exh=92.02 GM SB2.2 NASCAR SBC in ported shape
Int=5.794 Exh=3.598 Int=147.2 Exh=91.39 GM SB2.2 12480011 SBC 2.180/1.610 in ported shape
Int=5.503 Exh=3.393 Int=139.8 Exh=86.18 GM LS 5.7 Liter in ported shape
Int=5.488 Exh=3.315 Int=139.4 Exh=84.20 GM LS 6.0 Liter in ported shape
Int=5.591 Exh=3.395 Int=142.0 Exh=86.23 GM L92 casting#823 out-the-box shape 2.165/1.590 valves
Int=5.628 Exh=3.328 Int=143.0 Exh=84.53 GM LS-7 12578449 CNCd OEM shape
Int=5.478 Exh=2.988 Int=139.1 Exh=75.90 GM Vortec cast-iron 10239906 out-of-box shape
Int=5.875 Exh=3.668 Int=149.2 Exh=93.17 GM C5R 12480090 out-of-box shape
Int=5.488 Exh=3.315 Int=139.4 Exh=84.20 GM LS-1 in ported shape
Int=5.433 Exh=2.878 Int=138.0 Exh=73.10 GM LT-4 12555690 in ported shape
Int=5.995 Exh=3.355 Int=152.3 Exh=85.22 GM canted-valve SBC in ported shape
Int=5.265 Exh=2.828 Int=133.7 Exh=71.83 NHRA Stocker 14101081 1.840/1.500
Int=5.985 Exh=0.000 Int=152.0 Exh=0.000 Buick/Dart Chevy SBC 10 deg
Int=5.633 Exh=3.041 Int=143.1 Exh=77.24 RHS 12030 alum 235 CC 2.080/1.600 out-of-box shape
Int=5.487 Exh=3.130 Int=139.4 Exh=79.5 World Products SBC aluminum 2.125/1.600 Ported Shape
Int=5.350 Exh=2.875 Int=135.9 Exh=73.03 World Products SBC cast-iron I037 0804111288E 200 CC 2.020/1.600 Ported Shape
Int=5.475 Exh=2.975 Int=139.1 Exh=75.57 Dart Iron Eagle Platnium 49CC 10710040PF
Int=5.526 Exh=3.058 Int=140.4 Exh=77.67 ProAction SBC 223400035A 235CC 23deg
Int=5.465 Exh=2.888 Int=138.8 Exh=73.36 Pro TopLine 235cc SBC 23 deg in ported shape
Int=5.668 Exh=3.470 Int=144.0 Exh=88.14 Pro TopLine 14 deg 285cc SBC cast-iron in ported shape
Int=5.573 Exh=3.053 Int=141.6 Exh=77.55 Pro TopLine 235 CC SBC 2.080/1.600 SBC cast-iron in ported shape
Int=5.443 Exh=3.285 Int=138.3 Exh=83.44 Dart LS-X Style SBC in ported shape
Int=5.625 Exh=3.103 Int=142.9 Exh=78.82 Dart Pro1 230cc SBC alum out of box shape
Int=5.438 Exh=2.910 Int=138.1 Exh=73.91 Dart Pro1 227 CNC'd DRT018 2.100/1.600 SBC alum
Int=5.728 Exh=3.588 Int=145.5 Exh=91.14 Dart 10 deg SBC alum 2.180/1.550
Int=5.598 Exh=3.605 Int=142.2 Exh=91.57 Dart 18 deg SBC alum 2.150/1.600 max-Ported shape
Int=5.470 Exh=3.015 Int=138.9 Exh=76.58 Pontiac-Brodix 23 deg SBC 10033867 ported shape
Int=5.535 Exh=3.190 Int=140.6 Exh=81.03 Brodix 11x SUPR spec Heads 2.080/1.600
Int=5.450 Exh=3.253 Int=138.4 Exh=82.63 Brodix 12 2.150/1.600 in ported shape
Int=5.968 Exh=3.330 Int=151.6 Exh=84.58 Brodix 12X SBC spread-port in ported shape
Int=5.950 Exh=3.510 Int=151.1 Exh=89.15 Brodix 12X12RP SBC Weld Tech CNC'd 2.200/1.600
Int=5.560 Exh=3.233 Int=141.2 Exh=82.12 Brodix-WeldTech CNC 10XWT SBC 2.100/1.600 out-of-box
Int=5.641 Exh=3.393 Int=143.3 Exh=86.18 Brodix 18 SBC CNCd 2.180/1.625
Int=5.515 Exh=3.008 Int=140.1 Exh=76.40 Brodix Track 1 SBC in ported shape
Int=5.899 Exh=3.545 Int=149.8 Exh=90.04 Brodix SBC EB2200 13.5deg 284.5cc
Int=5.571 Exh=3.318 Int=141.5 Exh=84.28 TFS-LS1 Style SBC CNCd Chambers & VJ out-of-box
Int=5.825 Exh=3.513 Int=148.0 Exh=89.23 All Pro 245 SBC 22-23 deg out-of-box shape
Int=5.579 Exh=3.305 Int=141.7 Exh=83.95 All Pro 245 SBC 22-23 deg CNCd & Ported
Int=5.430 Exh=3.260 Int=137.9 Exh=82.80 All Pro LS-X SBC in ported shape 2.055-1.600
Int=5.663 Exh=3.290 Int=143.8 Exh=83.57 AFR 00002418 LS-x out-of-box shape
Int=5.333 Exh=2.900 Int=135.5 Exh=73.66 AFR 210cc CNC 23 deg SBC
Int=5.494 Exh=2.884 Int=139.6 Exh=73.25 AFR 220cc older version 23 deg SBC 2.080/1.600 Ported shape
Int=5.318 Exh=2.950 Int=135.1 Exh=74.93 Canfield SBC 23-500-65 in ported shape
Int=5.576 Exh=3.474 Int=141.6 Exh=88.24 TrickFlow TFS-SBC-5 aluminum 2.150/1.625 in ported shape
Int=5.712 Exh=3.493 Int=145.1 Exh=88.72 Edelbrock 18deg aluminum 2.225/1.600 in ported shape
--- Chevy Big Block Heads ---
Int=6.800 Exh=3.375 Int=172.7 Exh=85.7 GM DRCE Darin Morgan
Int=6.650 Exh=3.100 Int=168.9 Exh=78.7 Reher Morrison BBC
Int=5.930 Exh=0.000 Int=150.6 Exh=000.0 Brodix BB1 Oval Port GPD 259CC 2.66 avg CSA Bill Jones
Int=5.780 Exh=0.000 Int=146.8 Exh=000.0 Brodix BB1 Oval Port BPD 256CC 2.69 avg CSA Bill Jones
Int=6.125 Exh=0.000 Int=155.6 Exh=000.0 Brodix BB1 Oval Port GPD 288CC 2.87 avg CSA Bill Jones
Int=5.935 Exh=0.000 Int=150.8 Exh=000.0 Brodix BB1 Oval Port BPD 284CC 2.92 avg CSA Bill Jones
Int=6.090 Exh=0.000 Int=154.7 Exh=000.0 Brodix BB1 Oval Port GPD 272CC 2.720 avg CSA Bill Jones
Int=5.875 Exh=0.000 Int=149.2 Exh=000.0 Brodix BB1 Oval Port BPD 277CC 2.875 avg CSA Bill Jones
Int=7.145 Exh=4.533 Int=181.5 Exh=115.1 Alan Johnson 13 deg BBC Billet Head CNC'd 2.400/1.900
Int=5.123 Exh=4.398 Int=130.1 Exh=111.7 BAE Hemi VI Billet Head CNC'd 2.400/1.900
Int=7.080 Exh=4.158 Int=179.8 Exh=105.6 Sonny Leonard BBC 14.5 deg GPD in Ported Shape
Int=7.050 Exh=4.158 Int=179.1 Exh=105.6 Sonny Leonard BBC 14.5 deg BPD in Ported Shape
Int=6.473 Exh=4.323 Int=164.4 Exh=109.8 Dart Big Chief 18 deg BBC Good-Port in ported shape
Int=6.451 Exh=4.323 Int=163.9 Exh=109.8 Dart Big Chief 18 deg BBC Bad-Port in ported shape
Int=6.611 Exh=4.446 Int=167.9 Exh=112.9 Dart/Olds 14 deg BBC Good-Port in CNCd shape
Int=6.522 Exh=4.446 Int=165.7 Exh=112.9 Dart/Olds 14 deg BBC Bad-Port in CNCd shape
Int=6.904 Exh=4.638 Int=175.4 Exh=117.8 Dart Big Chief 11 deg BBC Good-Port in CNCd shape
Int=6.817 Exh=4.638 Int=173.2 Exh=117.8 Dart Big Chief 11 deg BBC Bad-Port in CNCd shape
Int=6.755 Exh=4.485 Int=171.6 Exh=113.9 Dart Big Chief 11 deg BBC Good-Port in CNCd shape ( latest design 2011 )
Int=6.740 Exh=4.485 Int=171.2 Exh=113.9 Dart Big Chief 11 deg BBC Bad-Port in CNCd shape ( latest design 2011 )
Int=6.124 Exh=3.590 Int=155.6 Exh=91.19 Edelbrock-24 degree BBC Good-Port in ported shape
Int=6.030 Exh=3.590 Int=153.2 Exh=91.19 Edelbrock-24 degree BBC Bad-Port in ported shape
Int=6.200 Exh=3.865 Int=157.5 Exh=98.17 Edelbrock-GM 14044861 BBC Good-Port in ported shape
Int=6.115 Exh=3.865 Int=155.3 Exh=98.17 Edelbrock-GM 14044861 BBC Bad-Port in ported shape
Int=6.028 Exh=3.673 Int=153.1 Exh=93.29 CFE-BMF 385CC CNC'd BBC Good-Port 245-Porting
Int=5.868 Exh=3.673 Int=149.1 Exh=93.29 CFE-BMF 385CC CNC'd BBC Bad-Port 245-Porting
Int=6.068 Exh=3.513 Int=154.1 Exh=89.23 Merlin Grumpy cast-iron BBC Good-Port in ported shape
Int=5.945 Exh=3.513 Int=151.0 Exh=89.23 Merlin Grumpy cast-iron BBC Bad-Port in ported shape
Int=6.120 Exh=3.448 Int=155.5 Exh=88.39 Dart-Pro-1 325CC BBC Good-Port in ported shape
Int=6.013 Exh=3.448 Int=152.7 Exh=88.39 Dart-Pro-1 325CC BBC Bad-Port in ported shape
Int=6.120 Exh=3.501 Int=155.5 Exh=88.93 Dart 308CC Iron_Eagle Good-Port in ported shape
Int=5.983 Exh=3.501 Int=152.0 Exh=88.93 Dart 308CC Iron_Eagle Bad-Port in ported shape
Int=5.957 Exh=3.525 Int=151.3 Exh=89.54 GM 1077 D-Port BBC alum GPD in ported shape no exh vane
Int=5.815 Exh=3.525 Int=147.7 Exh=89.54 GM 1077 D-Port BBC alum BPD in ported shape no exh vane
Int=5.868 Exh=3.303 Int=149.0 Exh=83.90 GM 990 BBC cast-iron Good-Port in ported shape
Int=5.760 Exh=3.303 Int=146.3 Exh=83.90 GM 990 BBC cast-iron Bad-Port in ported shape
Int=5.913 Exh=3.303 Int=150.2 Exh=83.90 GM 026 BBC cast-iron Good-Port in ported shape
Int=5.710 Exh=3.303 Int=145.0 Exh=83.90 GM 026 BBC cast-iron Bad-Port in ported shape
Int=5.975 Exh=3.380 Int=151.8 Exh=85.85 GM 781 BBC cast-iron Good-Port in ported shape
Int=5.820 Exh=3.380 Int=147.8 Exh=85.85 GM 781 BBC cast-iron Bad-Port in ported shape
Int=6.192 Exh=3.496 Int=157.3 Exh=88.80 Patriot Perf alum 320 CC 2.300/1.880 Bad-Port in ported shape
Int=6.421 Exh=3.496 Int=163.1 Exh=88.80 Patriot Perf alum 320 CC 2.300/1.880 Good-Port in ported shape
Int=5.813 Exh=3.580 Int=147.7 Exh=90.93 ProFiler alum 320 CC 2.300/1.880 Bad-Port in ported shape
Int=6.025 Exh=3.580 Int=153.0 Exh=90.93 ProFiler alum 320 CC 2.300/1.880 Good-Port in ported shape
Int=6.121 Exh=3.462 Int=155.5 Exh=87.93 Pro TopLine RHS BBC cast-iron heads 2.300/1.880 Bad-Port in ported shape
Int=6.407 Exh=3.462 Int=162.7 Exh=87.93 Pro TopLine RHS BBC cast-iron heads 2.300/1.880 Good-Port in ported shape
--- Chrysler Heads ---
Int=6.475 Exh=4.335 Int=164.5 Exh=110.1 Chrysler Hemi 2006 NHRA ProStock 2.550/1.822
Int=4.660 Exh=3.208 Int=118.4 Exh=81.48 Chrysler Hemi Indy Legend in ported shape
Int=5.958 Exh=3.968 Int=151.3 Exh=100.8 Chrysler Zeus P4532847 2.200/1.600 CNC'd shape
Int=5.875 Exh=3.915 Int=149.2 Exh=99.44 Chrysler Zeus P4532847 2.200/1.600 max-Ported shape
Int=5.965 Exh=3.905 Int=151.5 Exh=99.19 Chrysler W8 ProStock Truck in ported shape
Int=6.288 Exh=4.020 Int=159.7 Exh=102.1 Chrysler P5 Hemi ProStock Truck in ported shape
Int=4.093 Exh=3.123 Int=104.0 Exh=79.32 Chrysler Hemi 2780559-M cast-iron NHRA Stocker
Int=4.948 Exh=3.140 Int=125.7 Exh=79.76 Chrysler 596 cast-iron out-of-box shape
--- Pontiac Heads ---
Int=5.163 Exh=5.623 Int=131.1 Exh=142.8 Edelbrock-Pontiac alum out-of-box shape
Int=5.305 Exh=5.488 Int=134.8 Exh=139.4 Pontiac CV-1 Roland Racing in Ported shape 2.250/1.720
--- Ford Heads ---
Int=5.032 Exh=3.015 Int=127.8 Exh=76.58 Ford SBF alum AFR CNC'd 2.080/1.600
Int=5.625 Exh=3.524 Int=142.9 Exh=89.51 Ford BBF D2OE-AB 2.250/1.770
Int=6.465 Exh=5.126 Int=164.2 Exh=130.2 BBF Blue Thunder Thor 2.480/1.850
Int=5.873 Exh=3.571 Int=149.2 Exh=90.70 Edelbrock SBF Glidden-Victor GV2 CNC'd shape 2.200/1.600
Int=5.788 Exh=3.228 Int=147.0 Exh=81.99 Edelbrock SBF #7721 Ford out-of-box shape
Int=5.953 Exh=3.685 Int=151.2 Exh=93.60 Edelbrock SBF #7731 Ford CNC'd 2.200/1.600 shape
Int=5.135 Exh=2.995 Int=130.4 Exh=76.07 Ford Edelbrock Victor Jr 2.055/1.600
Int=5.145 Exh=3.290 Int=130.7 Exh=83.57 Ford TrickFlow Street-Heat aluminum in Ported shape
Int=5.828 Exh=4.408 Int=148.0 Exh=112.0 Ford TrickFlow A460 Bowl blended VJ 2.400/1.920
Int=5.295 Exh=4.478 Int=134.5 Exh=113.7 Ford M6049C3 ported shape 2.150/1.600 2nd design
Int=4.979 Exh=4.317 Int=126.5 Exh=109.7 Ford M6049C3 ported shape 2.150/1.580 1st design
Int=5.065 Exh=0.000 Int=128.7 Exh=0.000 Ford SBF Boss 302 242CC Ported
Int=4.873 Exh=0.000 Int=123.8 Exh=0.000 Ford C9OE SBF 351W 148.1 CC
Int=5.078 Exh=3.943 Int=129.0 Exh=100.2 Ford CHI 3V 218cc 2.190/1.655 ported form
--- Honda Heads ---
Int=3.753 Exh=3.605 Int=95.33 Exh=91.57 Honda S2000 4-valve
Formula=> Average_CSA = Port_Volume_CC / (Port_CenterLine_Length * 16.387)
Metric Conversion=> Inches = MilliMeters * .039370079
Thanks for the explanation Larry.
When doing the roof, I take it that the valve guide is not present at that point, so you can just let the tape easily follow the contour. Then you install the guide and valve and drip it with those items in place for the cc volume?
no, the guide and/or guide boss are always in the Port when i measure the Roof ,Drail24 wrote: ↑Sat Sep 19, 2020 8:21 pm Thanks for the explanation Larry.
it would be great if they weren't
i snake the tape around the guide boss best i can .
i'll post a few pics later what it looks like
Pictures on measuring Port CenterLine Lengths :
you then carefully pull the Tape out the Port
and measure its Length with Dial Calipers .
