YES YES YES YES
Stock Eliminator secrets?
Re: Stock Eliminator secrets?
YES YES YES YES
Probably shouldn't comment, but don't the newer votec heads flow better, but they aren't, "1st Gen.", design heads?
Class racing is all about specific casting numbers. You need to run the specific casting that your combo came with. (Unless there is an approved replacement)
The Vortecs do flow better, but there not a "early" head. A 441 head responds exceptionally well to mods, and will flow with a modified Vortec from what I've seen. Theres 441 castings that are better than other 441 castings.
Actually, the 327-275 combo is one of the least popular SBC's to build for Stock, especially with an automatic. The 350's (255/295/300 horse versions) and the 305's are the dominant SBC's in F/G/H class. The 350's and 305's are better than the 327-275, mainly in the area of torque and cylinder heads.
How can you spot the "good" 441 heads? The engine I built for my Nova was a virgin '69 L65 250hp 350 with 441s. I went with Vortecs, but I've still got the 441s that came off a (high-mileage) running engine.
On the bottom of the head the casting number will be parallel to the intake runner.novadude wrote: ↑Wed Sep 30, 2020 8:48 amHow can you spot the "good" 441 heads? The engine I built for my Nova was a virgin '69 L65 250hp 350 with 441s. I went with Vortecs, but I've still got the 441s that came off a (high-mileage) running engine.
Does icing down a cast iron intake manifold help?
-Can it hurt?
-Is there a better way to approach this?
-How do you address the QJet tendency to get rich at higher rpm?
Back to the pump to test fuels:
Testing fuels may require moving the cam around to chase any crumbs that may be there. This quick change setup lets us change cam timing quickly w/o messing with the balancer...a couple sips of coffee and it's ready for another pull:
No eye candy, here....yawn.
Do plug wires matter? Maybe.
-Can it hurt?
Looking very close at the pic of the secondary air bleed tubes... depth would matter, as does position of Holley Emulsion bleeds. Do class rules allow you to modify those tubes? I've got some thoughts....
Still looks better than modern engine bays.
Chevyfreak.
Bowtie for life
Something I noticed on the engine bay photo above... a PCV valve. Seems like even mild street engine guys love to eliminate them and run open breathers (I don't agree, BTW... PCV = good). Really didn't expect to see a PCV on a stocker.
on my Dyno tests ... theres a HP gain with modified PCV when using the relatively restricted flowing 4GC Carb
tenxal wrote: ↑Fri Oct 02, 2020 8:05 am Does icing down a cast iron intake manifold help?
-Can it hurt?
... you mean during a Dragstrip Run ? , or just on a Dyno tests ? or both ?-How do you address the QJet tendency to get rich at higher rpm?
i guess you tried black electrical tape mod on the QJet rear metering rod holes ?
and theres a custom gasket that does the same thing
Q-Jet rich at WOT is usually a metering rod problem. First make sure that the fuel pressure isn't creeping up or the float level isn't doing something goofy. There's a plastic stick tool to check float level with the engine running.
I used to have a chart with all of the metering rods listed from lean to rich. There are two letters stamped into all of the factory metering rods for identification. I'm sure it's still available somewhere. The metering rods with the skinny tips run the richest when the air valve is open. It looks like GM didn't want their engines to ever run lean at WOT, so they dump fuel in like crazy when the air valve is wide open.
The hanger height is critical. Spacing the hanger higher makes it richer. Bending the tangs to lower the metering rods makes it leaner. Carefully measure the hanger height (I used to use two aluminum plates and hang the hanger over the edge of one and measure the gap to the other plate). It might only need a 0.020" adjustment, but you need to know where you started first.
The tape trick helps too, but it's likely a hanger height adjustment that'll make the difference.
And for those not familiar with a Q-Jet, the two outboard "tubes" act more like a secondary accelerator pump than an "emulsion tube." The tubes feed fuel through holes just under the secondary air valve to add fuel just as the air valve cracks open.
