4.365 Oil Ring in 4.370 Bore
Ishiftem
Post by Ishiftem »
All I can find is standard tension oil rings for my 4.370 bore. They are 3/16. I can however find lots of choices for a 4.365 bore. What would happen if I ran a 23 lb ring for a 4.365 bore in a 4.370 bore? Or a 18 lb? The second ring will be a napier for a 4.365 bore. No vacuum pump. Just a pan evac to the headers. Thanks!
Re: 4.365 Oil Ring in 4.370 Bore
Math says the end gap would be .0157" greater. Also, a low-tension ring in a larger bore becomes that much lower tension.
Let's wait to see what those who've actually done it have to say.
LSP
Post by LSP »
Ishiftem wrote: Sat Jan 16, 2021 1:51 pm All I can find is standard tension oil rings for my 4.370 bore. They are 3/16. I can however find lots of choices for a 4.365 bore. What would happen if I ran a 23 lb ring for a 4.365 bore in a 4.370 bore? Or a 18 lb? The second ring will be a napier for a 4.365 bore. No vacuum pump. Just a pan evac to the headers. Thanks!
About a 3 lb. change in tension
A 'file fit' 4.365" ring would typically be +~0.005"...
Ishiftem
Post by Ishiftem »
I've looked through Total Seal, Mahle, and Hastings. The 4.370 bore size is a black hole. I know a file fit 4.365 would technically be +.005 which would be a ring for a 4.370 bore size. They just don't exist except for a standard tension. That's why I was asking about a 4.365 oil ring in a 4.370 bore.
BillK
Post by BillK »
Before you go crazy with this I would pick up the phone and called Total Seal. I think they will make you whatever you want if they dont already have it. Just because its not in the catalog does not mean its not available.
ProPower engines
Post by ProPower engines »
Ishiftem wrote: Sun Jan 17, 2021 5:50 pm I've looked through Total Seal, Mahle, and Hastings. The 4.370 bore size is a black hole. I know a file fit 4.365 would technically be +.005 which would be a ring for a 4.370 bore size. They just don't exist except for a standard tension. That's why I was asking about a 4.365 oil ring in a 4.370 bore.
If you asked for a +.010 set for a 4.360 bore ( Ford 429/460 ) they can do that guessing you are at .030 over on your current bore. That would be +.010 on std ring set for a 429/460 ford in what ever ring dimensions you need should get the job done.
I did the same thing with a BBC build a couple years back. Asked for a drop in 4.375 ring set no problem.
That would get you your ring set there as well =D>
Just went through the same thing with a 4.105 bore build. Total seal came through then as well =D> =D>
engineguyBill
Post by engineguyBill »
The oil ring assembly is not oversize in file-fit ring sets, only the top and second rings are manufactured .005" oversize. If you can find a ring set that contains a 4.370" ring package, that is what I would recommend that you use. Standard tension oil ring package is the best choice for 95% of the engines on the road.
Bill
SAE Member (30 years)
Geoff2
Post by Geoff2 »
You could use Buick 455 + 060 rings [ 4.312 std ]
or Chrys 400 + 030 [ 4.34 std ]
Ishiftem
Post by Ishiftem »
Called Total Seal. I think it was Bob I talked to. Gave me part # msl9190 130. That has a 12-18 lb oil ring with a Napier second. When I looked it up it’s for a 4.380 bore. No way I’m shoving those into a 4.370 bore. I’m trying to make hp not kill it. Maybe I’ll email Kieth. I think I still have his email.
Nut124
Post by Nut124 »
Why not file it to fit?
When you squeeze a ring down beyond its design diameter range, it no longer provides sufficiently uniform contact pressure.
Nut124
Post by Nut124 »
MadBill wrote: Mon Jan 18, 2021 9:32 pm When you squeeze a ring down beyond its design diameter range, it no longer provides sufficiently uniform contact pressure.
I thought 0.010 over is OK. Not?
rebelyell
Post by rebelyell »
FWIW
certainly don't suggest following:
a late pal o' mine owned & built & tuned motors for a supertruck CT asphalt piece. Very much like a late model.
Anyway, typical 2 bbl 355, iron bowtie heads, 6" rods, flattops, 5-7 swap, lift rule, flat solids and fuel restricted to track gas.
Pal tried running without any oil rings but with a pan full of Klotz kart oil heavily spiked with methanol.
Man it was fast ... until it loudly broke; terminal
