Building A Nostalgic 1970s Fuelie Headed 350 SBC
Re: Building A Nostalgic 1970s Fuelie Headed 350 SBC
I would say "no way" but since Mark is building this you can bet he will find a way to make it run what he says it will.
I'am curious why you would say no way?
It uses a Milodon rear sump oil pan.
Some more pictures
Walk in the parkvortecpro wrote: ↑Sat May 01, 2021 11:22 pm Building a 4.060 X 3.480 360 inch SBC, 618 2 bolt block, factory 5.7 rods, cast factory crank, flattop pistons, 2.02 fuelie heads, solid flat tappett cam, .515 lift @ valve, 242 @ .050, 108, installed @ 104. Air gap intake, Milodon Chevy II oil pan. Dyno test Monday. Looking for a 10 sec Chevy II.
Tom
Love it!
Taking a bunch of junk & building something more than the sum of it's parts is much more rewarding than buying fancy shit & bolting it together.
YES.........were not spending any money to run 10s are we.............................
I have to agree. Right out of the 80s.zums wrote: ↑Sun May 02, 2021 9:23 pmWalk in the parkvortecpro wrote: ↑Sat May 01, 2021 11:22 pm Building a 4.060 X 3.480 360 inch SBC, 618 2 bolt block, factory 5.7 rods, cast factory crank, flattop pistons, 2.02 fuelie heads, solid flat tappett cam, .515 lift @ valve, 242 @ .050, 108, installed @ 104. Air gap intake, Milodon Chevy II oil pan. Dyno test Monday. Looking for a 10 sec Chevy II.
Tom
This is amazing. Beautiful engine by the way ! Is it going in the dyno ?
Can you tell us more about the car setup the engine is going in ?
Heres the good news- it will be dyno tested today. The car is a NHRA legal F/SA Chevy II, that has been put on the street, T350 8 inch converter, 4.10 gear TRRC 12 bolt, 2900 pounds ready to run.
Thats A CHEVY II
10'a seems like a HUGE stretch for basically a flat top 350 with double hump heads... and a cam with barely over 0.500" lift.
That is, unless it's a 'pop can' on wheels with a ton of gear/converter and a well sorted out drivetrain/suspension akin to a Stock/Super Stocker.
Personally, I think you'll need more head and camshaft to get into the 11's if it resembles any kind of actual street car.
Good Luck
Good Luck
I don't know how much to trust online calculators , but Wallace Racing Calculators calls for 430 hp to run 10.99@124 in the 1/4 at 2900 lbs. . Mark did say it was a NHRA legal F/stocker so it should be a well sorted chassis. just my .02 .Dan
After reading the rest of the post, it looks like a much more potent combination than originally appears on the surface. Likely some VERY ported heads, careful parts selection and a lot of attention. to detail... compared to a garden variety flat top 350 in a pedestrian street car. A fully prepped powerplant in an ex Stocker is a different story. lol6.50camaro wrote: ↑Mon May 03, 2021 12:14 pm I don't know how much to trust online calculators , but Wallace Racing Calculators calls for 430 hp to run 10.99@124 in the 1/4 at 2900 lbs. . Mark did say it was a NHRA legal F/stocker so it should be a well sorted chassis. just my .02 .Dan
Sounds like fun!
What will be the static compression ratio? What does the intake port flow at .600 lift? Thanks
