oil squirters to rod/piston/crank clearance
John@RED
Post by John@RED »
Hello, any advice about brass oil squirters being 0.04 away from piston and crankshaft counterweigh at BDC, and 0.04 away from rod leg at half stroke?
Can't really get it further away from crank, piston and rod, that's the half way from everything: is 0.04 enough in your experience? Thanks
Re: oil squirters to rod/piston/crank clearance
Post by mag2555 »
If something in the rotating assy is flexing enough that .040” gets eaten up then you have a motor that’s going to come apart on you anyway!
allencr267
Post by allencr267 »
Well said!
But maybe metric?
Tom68
Post by Tom68 »
John@RED wrote: Sat May 14, 2022 4:52 am Hello, any advice about brass oil squirters being 0.04 away from piston and crankshaft counterweigh at BDC, and 0.04 away from rod leg at half stroke?
Would depend how they're mounted, if they vibrate from getting belted senseless with oil firing off the rotating assembly they could break, if they're a solid fittings mounted in the block no problem of course.
BCjohnny
Post by BCjohnny »
allencr267 wrote:But maybe metric?
My thoughts entirely
If he's missed the zero off and means 0.040" that's one thing, but if OP means 0.04 mm he's down to only 0.0016" (rounded)
He really needs to clarify to get any kind of meaningful answer
John@RED
Post by John@RED »
Not metric, imperial! :D
I know that nothing shouldn't flex so much, but oil squirters jet is long and slim, so quite worried
