Speaking of welding cast iron
- Super_Stock
- New Member
Re: Speaking of welding cast iron
Thanks for posting
Linseed oil used to be (is?) commonly used, not sure of price, hence cost effectiveness, these daysSchmidtMotorWorks wrote:Molasses sounds too expensive, maybe some mixture of oil and tar?
With the 'added value' of machining, hence sale of a finished product, maybe the margin is there for most things
Those videos are of the successes, imagine what the fails were like.Super_Stock wrote: ↑Thu Jul 14, 2022 3:15 am Just an example of what you can do, if your willing to do it.
Linseed oil sounds too expensive, I'm thinking used motor oil and ashes.BCjohnny wrote: ↑Thu Jul 14, 2022 2:11 pmLinseed oil used to be (is?) commonly used, not sure of price, hence cost effectiveness, these daysSchmidtMotorWorks wrote:Molasses sounds too expensive, maybe some mixture of oil and tar?
The heavy duty bench grinder stand @15:22 is kind of fun.
I wonder how secure the valve guides, other valve seats, mini combustion chambers and freeze plugs and pipe plugs are after being baked.
The way the replacement seats machined, do they look like they are made of a decent material ?
- Dave Koehler
Probably just cast iron cut from a tube or solid round on a lathe.
A friend had just taken off his eye protection...after working on some Mercedes wheel bearings. His brother hit the race with a hammer and pin. A micro sliver chipped off the race, and flew 'across the shop' to inbed into the center of his eye. Destroyed his cornea...was just lucky it struck om the pupil area. Otherwise it would have messed up the eye.Chris_Hamilton wrote: ↑Tue Jul 12, 2022 7:50 pm After getting a 5mm long sliver of steel (wearing safety glasses) from grinding, fully embedded in my eye, and going through 3 weeks of eye scrapings to remove the rust rings that had formed, and tremendous pain I now only will use a full face shield. The thing about the piece of steel that got in my eye, I had no clue other than feeling like a piece of grit had gotten in my eye. Blinked a few times and it was gone. Only after a couple of days and waking up in agony did I notice the black spot in the white of my eye.
He had another cornea grown, bi-focal, but it's not optimal.
He was wearing some heavy duty gloves. Must have been something aggressive. Vinegar mixture...likely would not have used them.
A mate was trying to unlock the tapered lock washer on a Benz truck wheel with a hammer and punch, lost an eye.Tartilla wrote: ↑Thu Sep 15, 2022 11:29 pmA friend had just taken off his eye protection...after working on some Mercedes wheel bearings. His brother hit the race with a hammer and pin. A micro sliver chipped off the race, and flew 'across the shop' to inbed into the center of his eye. Destroyed his cornea...was just lucky it struck om the pupil area. Otherwise it would have messed up the eye.Chris_Hamilton wrote: ↑Tue Jul 12, 2022 7:50 pm After getting a 5mm long sliver of steel (wearing safety glasses) from grinding, fully embedded in my eye, and going through 3 weeks of eye scrapings to remove the rust rings that had formed, and tremendous pain I now only will use a full face shield. The thing about the piece of steel that got in my eye, I had no clue other than feeling like a piece of grit had gotten in my eye. Blinked a few times and it was gone. Only after a couple of days and waking up in agony did I notice the black spot in the white of my eye.
I love those videos. Especially the ones that they do more of the head rebuilding. As hacky as it seems to be, they actually do a decent job, and the heads would absolutely function. The ones I have seen, they replace all the guides, replace all the seats, re cut the seats on a makeshift set up on a mill with no fixturing, one guy just holds the head still, but they rough everything in with single angle blades for each angle, measure to make sure depths are correct, then another guy trues up the seats with a stone. I find it quite entertaining to watch how some of these 3rd world shit holes get stuff done. Another guy I like watching, not related to engines, but he cooks. Wilderness Cooking, or Outdoor cooking or something. He cooks stuff obviously outside, from some place that's way behind the times, his trade mark, is when he takes a bite, he always says "super" and gives a thumbs up. He is probably making more money than he ever dreamed of off youtube. Every video gets at least a million views.
I remember in our own country where true machinist and shops in the sixties and up to eighties use to do work like this so I can only assume that our country was a sh.. hole back then.And I would be willing to bet you in some states and town you can still find guys with skills like this and shops today.But some of you will never know because you just go and drop your damaged part with some shop and they farm it off to one of those shops.
The theme here seems to be, eye protection works. But Mr. Murphy us always lurking.
Eye pro in the Army is a thing now, for about 20 years. The issue is when I sweat a lot, it fogs up the lense....and I cannot see through the NVGs.
Rules need to have clear intent, and train competent people to follow them, and moat importantly, when to break them when the rule's intent is not the looming outcome.
More than just eye protection, the right kind of eye protection. When I got that piece of steel in my eye I had wrap around safety glasses on. It went underneath the glasses. A full face shield should be considered mandatory for any grinding operations.Tartilla wrote: ↑Sat Sep 17, 2022 6:03 pm The theme here seems to be, eye protection works. But Mr. Murphy us always lurking.
