Engine Block Value
Engine Block Value
Is there a place on this forum where on might be able to find out the value of an older 350 block ?
Re: Engine Block Value
How high is up?
These days, they're all older, so how old?
Two-bolt or four-bolt?
Standard, .030", .060"?
Two-piece or one-piece rear main seal?
Flat tappet or roller lifter?
Casting number?
1969 Its the 3932386 casting. 4 bolt mains . It has the 2482 main caps. Its standard bore. I purchased it from the local speed shop. Its been checked for cracks, The bores were sonic tested. Never blown up, no spun bearings etc. Threads are all good. It does not have the DZ suffix.
Do you have two posts asking the same question?
