Camshaft needle roller bearings
Wanted 6261-C351 small block ford needle roller cam bearing if anyone has a set for sell and want to get rid of there set let me know.Are if you know a source where they can be obtained.
Re: Camshaft needle roller bearings
I just used my last set. They stopped making them a long time ago. They were hard to come by 10 years ago.
I'm almost certain you can get a 55 mm babbitt bearing to fit the bores but then you'd need a 55 mm journal cam which probably doesn't help you.
Good luck.
I might try to see if I can get the company that made them to sell me a set .My old set of bearings have the company name and there is a part number on them.It just depends on if they will sell to a regular consumer are not.
