NEW 444ci ALL ALUMINUM SB2.2 - 854hp
NOT ALLOWED: Selling or reselling in a retail manner.
perfconn
Post by perfconn »
PBM aluminum block w/50mm roller cam bearings
Callies Magnum 4.125 stroke crank - 50#
Callies 6" Ultra 2" I-beam rods - 633 grams
JE 4.135 bore flattop pistons w/.043-.043-3mm rings
Hendricks DH8C SB2.2 heads - 33.4cc chambers
2.180 - 1.600 - 5/16 titanium valves
JHE 10C valve springs
Exeldyne tool steel retainers
Jesel 1.70 - 1.75 shaft rockers
Comp Cam 50mm 8620 billet cam
Morel .904 lifters
GM 699 intake
Cast aluminum valve covers w/oilers
MSD distributor
MSD crank trigger
Scott sparkplug wires
Dan Olson aluminum drysump oilpan
Bosch sparkplugs
ATI balancer
Edelbrock waterpump
Winning Edge 1000cfm gas carburetor
14.24 compression
All brand new parts including heads
Valves - .012 hot
Timing - 29*
854hp @ 7000rpm
697 # torque @ 5800 rpm
$27,500 cash
Pictures & dyno sheets are available by email
Email : terry.marciaburnett@gmail.com
Phone : 865-567-6943
perfconn
Re: NEW 444ci ALL ALUMINUM SB2.2 - 854hp
Post by perfconn »
Pictures of parts
perfconn
Post by perfconn »
Couple more pictures after we got it off dyno.
Bigchief632
Post by Bigchief632 »
Is this the one from the Quench thread? Seemed to have worked pretty well.
perfconn
Post by perfconn »
Yep,thats it.It liked a little more timing than the last 4" stroke engine but still a pretty good engine.We were having trouble with making a smooth pull because it made so much torque.Thought the problem was brake water tank had too much water in it.Turned out we needed to open the brake water valve a little more to compensate for torque.I think it has more to show if we had not quit.We tried 2 different carburetors,a 950 Stealth & a 1000cfm Winning Edge.Started with 28* timing,then a couple of pulls with 26 degrees timing(rich)& then put 28.5*(lean) in before we quit.All were on Renegade 112 gas.Engine is solid with no leaks,buyer will just need to get the most out of it with his tuning.
perfconn
Post by perfconn »
Price is negociable.Depends on whether you need carburetor & which one,or whether you need engine delivered or picked up here & whether you would like it dynoed again with you there.Call me if you are interested,I'm sure we can work something out.
perfconn
Post by perfconn »
I also have a video of one of the dyno pulls I can email you if you are interested in engine.
perfconn
Post by perfconn »
Price is lowered to $26,500
perfcon
Post by perfcon »
Sold - sold - sold
