After checking my moms old dryer for change, I decided to save and find more of these rear louvered panels to use as hood vents
vid https://youtu.be/zTJixQlithM
Repurposed Louvers For Hood Vents
Re: Repurposed Louvers For Hood Vents
WhY ? Plan is to cut out existing metal and weld, glue or pop rivet in ? Available louver punches with non of this, is too direct ?
CHEAP! Six of them cost me bout $67 and one was free. I spent more on two other types of hood vents, each set!
Also reuse-able since I plan to rivet, only mention welding cause they are steel.
