All for a 350 no doubt, 8.5:1 for a performer, it's a wonder they didn't suggest tracking down an old SP2P.
Edelbrock Torker II
Re: Edelbrock Torker II
This is on the list of necessities, but they don't give them away
We need to make some hard measurements, really hope it can be done.
This likely the best option if the Vic Jr doesn't fit.
https://www.holley.com/products/engine/ ... parts/8125
Weiand street warrior 8125
Same height as performer sbc
We are dealing with a tight budget here. The car owner want's to go fast at the track. As is now with a restricted exhaust and intake, the car will scare people in the passenger seat. Assuming an improved suspension and a shifter that works, I'm sure there is another easy 3 tenths in it with no changes to the motor. Realistically, the small heads are going to be the cork in the system. Everything on a 400 based engine needs to be bigger, but there isn't money for a $2,000 set of 75 cc chamber AFR heads. The question remains, will the Torker II be a significant improvement over the standard performer. The only reason I would consider it is because we have it.
My experiences with the sbc torker 2 and its equivalent low rise weiand xcelerator is you will not see an improvement. Even if the car et'd the same at the track, it would be a detriment if the car is driven on the street. It is better off w/ its current intake. Ive willingly traded those low rise single planes for stock non egr spreadbore cast iron intakes. If you want to see some other results involving torker 2 tests look up the times David Freiburger has dyno'd that intake against others. He's tested that intake 2-3 times in the last 20 years.
the torquerII is a dog. if there is any other choice, just toss it in the recycle bin.
How about the Holley 300-36 Street Dominator intake its a copy of the Z/28 - LT-1 intake from the late 60's early 70's was used on corvette 350-370 hp LT1 Vette's so it should clear the hood. Larger runners than the Edelbrock performer and can be found at a resemble price. I picked one up for a little over $100 everyone wants Air Gaps these days.
The vettes that had this high rise intake had a LT-1/ L78 LS6 style hood with a styled raised center .6.50camaro wrote: ↑Tue Oct 31, 2023 2:03 pm How about the Holley 300-36 Street Dominator intake its a copy of the Z/28 - LT-1 intake from the late 60's early 70's was used on corvette 350-370 hp LT1 Vette's so it should clear the hood. Larger runners than the Edelbrock performer and can be found at a resemble price. I picked one up for a little over $100 everyone wants Air Gaps these days.
This intake is too tall for the stock base model 68 72 vette flat hood.
No, it will reduce power in most of the range that motor is being used in and won't add appreciably above where it's being used.rfoll wrote: ↑Tue Oct 31, 2023 12:21 pm We are dealing with a tight budget here. The car owner want's to go fast at the track. As is now with a restricted exhaust and intake, the car will scare people in the passenger seat. Assuming an improved suspension and a shifter that works, I'm sure there is another easy 3 tenths in it with no changes to the motor. Realistically, the small heads are going to be the cork in the system. Everything on a 400 based engine needs to be bigger, but there isn't money for a $2,000 set of 75 cc chamber AFR heads. The question remains, will the Torker II be a significant improvement over the standard performer. The only reason I would consider it is because we have it.
Don't waste money on gaskets.
So far, I have been unable to find anything lower than what he has. Another possibility that occurred to me is the original Performer manifold. They are much larger and can be had cheap at a swap meet. I remember Big Joe speaking well abut the power he could make with one. I have no clue as to how high the carb pad is.
If you are using the aftermarket version of the 3310 carb with this air cleaner you want to cut off the choke horn for best results. The oem version carbs were different.
had down leg boosters and a shorter choke horn than the aftermarket carbs.
OER restoration parts has the correct air cleaner base you want. This is the lowest height air cleaner you will find and the right one for this job. May need minor mods to fit it.
If not big on chopping off the choke horn the Proform HP style center body upgrade kit is sweet.
