4412 carb
Re: 4412 carb
Ring Holley.
Re: 4412 carb
go to the holley site will give all stock jetting and how carb was built, replacement parts etc. I always set up to stock before tuning.
https://documents.holley.com/techlibrar ... isting.pdf
Re: 4412 carb
Recalibrating will be key since this carb was never employed to run on Ethanol cut pump fuel.
Re: 4412 carb
73 jet, 5.0 power valve from the factory.
If by pure stock, you're referring to a racing class, does the class require fuel be purchased at the track? And how much if any ethanol is in the mix?
Re: 4412 carb
Find a good chassis dyno to set up your individual setup.
Smokey
Smokey
Re: 4412 carb
Number 75 jets and no power valve; plug it.
With a 4 cylinder track engine, it will get you close.
Re: 4412 carb
I was hoping someone would say this ^^ OP could have used the search function and found several old threads and posts about exactly this scenario, 4 cylinder Holley 2bbl, if the search function worked.Walter R. Malik wrote: ↑Wed Jan 31, 2024 6:30 pmNumber 75 jets and no power valve; plug it.
