Chevy 193 Swirl port Mission Impossible
Carnut1
Re: Chevy 193 Swirl port Mission Impossible
Post by Carnut1 »
They are 2.1" valves that flow 318 at high lift and a 1.94" that flows 260
631-816-4911
9:00am - 9:00pm EST
A lot easier to get a -$treetRa¢e- if you show up with ID-able "swirl port" truck heads on vs CNC SRH V Factor heads on your racer.
Is the 1.94" version with a 50° valve job angle?
Carnut1
Post by Carnut1 »
Yes
631-816-4911
9:00am - 9:00pm EST
Incredable good thread and with videos.
Thanks thanks Charlie for your efforts.
You've allowed us to learn with you.
You are one of the guys that make this forum worth while.
Carnut1
Post by Carnut1 »
I am very busy so I don't give Speedtalk the time I used to. Thanks
631-816-4911
9:00am - 9:00pm EST
Medication. 😁 Seeing what happens now if the fin/ vane/ ramp is at the 8 o'clock position would be interesting to me..
Great videos.
Carnut1
Post by Carnut1 »
F-BIRD'88 wrote: Tue Jan 16, 2024 10:10 pm Medication. 😁 Seeing what happens now if the fin/ vane/ ramp is at the 8 o'clock position would be interesting to me..
Great videos.
I do quite a few videos on changing ramp clock positions and recording air and dykem flow patterns. 8:00clock happens. Thanks
631-816-4911
9:00am - 9:00pm EST
Eroy
Post by Eroy »
When are we going to see how they run on an engine?
Carnut1
Post by Carnut1 »
Not for a while. Thanks
631-816-4911
9:00am - 9:00pm EST
I will go back thru your videos and review them.
Thanks Charlie. ✔️
Doober
Post by Doober »
Gotta say I enjoyed your videos on these... I'm guessin' these won't be ideal at that port volume for something like TPI unless it was a mite bit over 350ci 😇
Carnut1
Post by Carnut1 »
Doober wrote: Wed Mar 20, 2024 1:19 am Gotta say I enjoyed your videos on these... I'm guessin' these won't be ideal at that port volume for something like TPI unless it was a mite bit over 350ci 😇
At 240cc and over 300 cfm they will need some compression and cubes! Thanks
631-816-4911
9:00am - 9:00pm EST
Bob Hollinshead
Post by Bob Hollinshead »
I enjoyed all of it! My son and I built a swirl port special a few years back that runs way harder than it should. Some mild port and chamber work, 1.6 exhaust valves, hyd roller cam, 9.3 compression, headers, rpm intake, 4180 hoĺley. Now after seeing Charlie's testing I've got some ideas to make it better.
Pro question poster.
Carnut1
Post by Carnut1 »
Bob Hollinshead wrote: Thu Mar 21, 2024 10:21 pm I enjoyed all of it! My son and I built a swirl port special a few years back that runs way harder than it should. Some mild port and chamber work, 1.6 exhaust valves, hyd roller cam, 9.3 compression, headers, rpm intake, 4180 hoĺley. Now after seeing Charlie's testing I've got some ideas to make it better.
I like it! Thanks!
631-816-4911
9:00am - 9:00pm EST
