Briefly, it appears that a decomposition product of a typical moly additive is both ferromagnetic and has a tan to brown appearance. This would be consistent with the additive fallout comment.
https://www.researchgate.net/publicatio ... opic_study
https://en.wikipedia.org/wiki/Iron(II)_molybdate
https://web.archive.org/web/20230117150 ... 13718-70-2
https://www.researchgate.net/publicatio ... 4_nanorods
https://www.google.com/search?q=ferroma ... e&ie=UTF-8
Mystery sludge
Re: Mystery sludge
Re: Mystery sludge
It's more of "my budget" than rules...Or rules of the household trump the track rules
Re: Mystery sludge
I’ve seen sludge like that after using royal purple but not thick and not as much but this was only with 15 runs down the track.I just quit using it and it went away.
Re: Mystery sludge
On a side note here, and I know it’s out of your price range for this type of racing unless you find a used one, but your center main ware issue is from needing a 8 counter weight crank due to your hp and rpm level stuffed in a factory block.
Re: Mystery sludge
Been there those household rules are a lot tougher to slide by than a tech inspector at the track,lolLizardracing wrote: ↑Mon Apr 08, 2024 11:17 amIt's more of "my budget" than rules...Or rules of the household trump the track rules
