Intake Manifold Porting Show ‘n Tell
ChopperScott
Re: Intake Manifold Porting Show ‘n Tell
Post by ChopperScott »
steve cowan wrote: Fri Apr 12, 2024 1:08 pm Nice looking work as always scott
Is there a particular angle you work towards for carb pad to plenum EG - 12 - 15 degrees?
Lots of work taking out clover leaf by hand for sure
Thanks for sharing.
As you can see in the first pic, due to core shift, the carb pad is offset from the runners. In my experience, this is common on the 2970/2971 manifolds. On the sides, angle is a compromise to maintain runner length on the inner runners. Front and rear is pulled as far as casting permits.
mt-engines wrote: Fri Apr 12, 2024 8:15 pm Cool.. when will you have some results?
When I'm at liberty to share, I certainly will. As I mentioned earlier, Ron Winterhoff, of Ron's Porting Service, is familiar with my port work. To share a quote from Ron... "Great work, enjoy looking at your work, and I know by who you're working for that it makes HP."
WeingartnerRacing wrote: Fri Apr 12, 2024 9:38 pm Wonder why they didn’t have me port the manifold.
I never asked. I assumed it was due to your workload or time constraints. You're always welcome to send work to me if you're overloaded.
'73 Camaro Z/28 NETO/N
434 SBC 11:1, 1.294, 6.178 @ 108.87, 9.81 @ 134.93 (3060#, Naturally Aspirated, Sunoco Ultra 94)
Chopper Air Port 917-589-1278
Topsp33d
Post by Topsp33d »
Showing off my edelbrock 2828 converted to efi
I accidentally got some oven cleaner in the plenum so it’s looking dark but it’s got large radius at the plenum and large bell mouth
Topsp33d
Post by Topsp33d »
Ah geez I can’t link anymore from my phone for some reason. They just keep showing up as black images. Anyways it’s got the cloverleaf removed and has a 5” csa bell mouth to a 3ish” csa gasket
ChopperScott
Victor “E” vs Victor JR
Topsp33d
Post by Topsp33d »
Pardon my ignorance but does the “E” signify speed master foundry?
mt-engines
Post by mt-engines »
ChopperScott wrote: Fri Apr 12, 2024 11:26 am Edelbrock Super Victor 2970, ported at Chopper Air Port. This one is for 400+ cubic inches, running a set of AFR 220s (2.5 sq. in. MCSA, ported by Weingartner), pushing 8000 RPM with 450-500 HP of nitrous...
Exactly.
I'm guessing because some guy in a garage that bounces a burr around an intake, and started a thread to learn how to do this is better than you.
ChopperScott
Thank you, kind sir. I appreciate the vote of confidence. When you’re ready to send out a manifold, let me know.
ChopperScott
1980RS
Post by 1980RS »
ChopperScott wrote: Sat Apr 13, 2024 12:47 am Victor “E” vs Victor JR
They both look almost identical except for the bigger runners. Are you porting the "E" intake Scott?
ChopperScott
A few more manifolds ready for Mayhem!..
ChopperScott
ChopperScott wrote: Fri Aug 11, 2023 6:34 pm Final iteration of that Team G. It has been sold and shipped. It will be run on a 12.5:1 355 with Brodix 225 Dragonslayers and custom Jones cam peaking at 7000 rpm….
In a Camaro that never went quicker than 10.00 in the 1/4, it ran a 9.92 @ 137 after manifold swap with the same tune. It replaced an older, port matched, Victor Jr.
