l88 drop base
als427
l88 drop base
Post by als427 »
hi finally arrived , Im in the uk , bunch of stuff long overdue ordered.What do you guys do with the breather tube?
dont have one on my current set up - presumably cut it off and weld a plate over it?
Re: l88 drop base
Yes Remove that breather tube as it hits the carb on many non OEM setups.
There were various breather tube locations on the OEM applications over the years..
The carb's fuel bowm vent tubes need to be cut shorter and cut on an angle.
Your carb throttle linkage cable bracket will need to be modified to lower its mounting position as the air cleaner base sits lower.
1980RS
Re: l88 drop base
Post by 1980RS »
I just sold my "real" L-88 complete air cleaner last year for $3K, guy was thrilled to get it. Some other guy I see at local swap meets wanted it real bad but was only willing to pay $100 for it, LOL.
als427
Re: l88 drop base
Post by als427 »
holy crap!! $3k
1980RS
Re: l88 drop base
Post by 1980RS »
als427 wrote: Wed Apr 17, 2024 6:44 am holy crap!! $3k
Was in a factory GM box and never used. Got it when I was a kid (I'm now 69) at Chevy for get this, $35 :lol:
I made a good investment on that air cleaner.
In-Tech
Re: l88 drop base
Post by In-Tech »
Nice =D> =D> =D> =D> =D> =D> =D> =D>
-Carl
