Lube for valve stems?
MELWAY
Post by MELWAY »
I use a 50/50 mix of diff oil with a EP additive and lucas oil stabilizer.
It makes a really sticky lube that is still an oil but not a grease.
I work for GMH in australia and diff oil is what they use on valve stems
RW TECH
Post by RW TECH »
I either use straight 50W oil or EOS on valve stems.
Barbapapa
Post by Barbapapa »
RW TECH wrote:I either use straight 50W oil or EOS on valve stems.
I just started using EOS as assembly lube on cylinders and valve stems, it's nice to hear someone else doing that! I'm trying to break the old habit of using moly grease. I use that gooey red stuff on other parts, does anyone know what's in there?
Mike S.
e-tach
Post by e-tach »
RedLine assembly lube here - not to pasty, is rather thin
n2omike
Post by n2omike »
e-tach wrote:RedLine assembly lube here - not to pasty, is rather thin
Let it sit for a while, and it will dry up. I used to use it for almost everything, but, like Lubriplate, it's not good if it's going to sit for a while.
Set some out somewhere for a while, and you'll see.
Good Luck!
cpmotors
Post by cpmotors »
X2
Pete Graves
CPMotorworks,Inc.
Custom Engine Machining
Big Speed
Post by Big Speed »
The valve guide is one of the first places to get heat and the last place to get oil,we use STP on valve guides ,it stays if the heads sit around awhile before fireup, also use STP to keep valve spring shims in place while assembling heads.We do not use STP for anything else.
Keith Morganstein
Post by Keith Morganstein »
Big Speed wrote:The valve guide is one of the first places to get heat and the last place to get oil,we use STP on valve guides ,it stays if the heads sit around awhile before fireup, also use STP to keep valve spring shims in place while assembling heads.We do not use STP for anything else.
One problem with STP is it's hygroscopic. It takes up water and causes rust.
needforspeed66gt
Post by needforspeed66gt »
I use a mix of moly-graph and clevite bearing guard...have never had a problem.
Nate @steeldustmachine
Engine Machinist
cmw
Post by cmw »
CMW Oil supplies engine builders like Jon Kasse, Sonny's, Steve Schmidt, Carl Wegner is just to name a few that use CMW Oil Products. Only the Best use the Best products available.
CMW Oil
562-903-4571
Bob Cousimano
CMW Oil Company
CMW Motorsports Manufacture Aftermarket Porsche Billet Heads, Cylinder head Flow development, Engine Dyno Service
Racerrick
Post by Racerrick »
I use the red stuff like Clevite bearing guard or comp cam lube. I think its made by the Slip Kote company and packaged under various trade names.
af2
Post by af2 »
I use locktite 518! :lol: :lol:
Any oil is fine!
GURU is only a name.
Malvn
Post by Malvn »
Hi to all I use the Penn Grade Break in oil the Green stuff as many call it.And if I know that the heads are going to set a while I will use the 50weight Penn Grade oil :) Malvin
TORQUE INC
Post by TORQUE INC »
What would moly ever save ?
dunno but I dont think you want anymore solids in the oil than you can help.
I use the CMW stuff...sparingly.
TORQUE RULES !!!!
ClassKing
Post by ClassKing »
DITTO on the Clevite red goo. :!:
Function - the hidden math.
http://www.pontiacengines.com
