sbc 18 degree trick flow heads
BrazilianZ28Camaro
Re: sbc 18 degree trick flow heads
Post by BrazilianZ28Camaro »
Hello Gents
I know this is an Old tread, but I believe Its a good place to ask, I'd like to know If is possible to use a regular SBC intake bolted with angled plates with these Heads, like a Victor Ram.
'71 Z28 street strip car
Pump gas All motor SBC 427
3308 lbs-29x10.5 Hoosiers
NEW BEST ET
1.38 60' / 4.05 330' / 6.32@111.25mph
Tom68
Post by Tom68 »
Intake flange should be standard angle. The good 18 degree heads have raised ports.
BrazilianZ28Camaro
Tom68 wrote: Sun Feb 04, 2024 6:54 pm Intake flange should be standard angle. The good 18 degree heads have raised ports.
I believe by the flow numbers and Dyno results posted here, the Heads in question are the Trickflow ultra 18s, raised runners. Am I missing something?
NEW BEST ET
BrazilianZ28Camaro
They also have a different intake flange angle, that is why Im asking...
NEW BEST ET
Tom68
Post by Tom68 »
BrazilianZ28Camaro wrote: Sun Feb 04, 2024 7:11 pm
No, I missed the first page, thought it was a fresh post, used to look after a raised runner 18 degree motor, I'd assumed the intake flange was correct to block because the pushrods were still too dam close to the rocker cover rail.
