Interesting new carburetor from Pro Systems
289nate
Post by 289nate » Tue Oct 27, 2009 11:59 pm
Anyone check out the new SV1 that Patrick is selling? Looks and sounds very interesting.
http://www.prosystemsracing.com/svseries.html
R.Olds
Post by R.Olds » Wed Oct 28, 2009 12:11 am
Dammmm, I dont think my toilet has a bore that big!
Ron C.
Post by Ron C. » Wed Oct 28, 2009 12:49 am
It looks like the old "Fish" carb from many years ago.
Blessings.........Ron.
Creekside Racing Ministry
John 14:6
Ron Clevenger
CSU Gas Dominator ProCharger nonintercooled
Top Eliminator West http://www.topeliminatorwest.net
Steve Morris http://www.stevemorrisengines.com
6.49@219mph (still tunning)
jmarkaudio
Post by jmarkaudio » Wed Oct 28, 2009 1:33 am
Ron C. wrote:It looks like the old "Fish" carb from many years ago.
Mark Whitener
http://racingfuelsystems.myfunforum.org
____
289nate
Post by 289nate » Wed Oct 28, 2009 1:58 am
I think there are a few things it looks like. LOL Have you checked out the boosters on it? That is the part I find most interesting.
Lasher...
Post by Lasher... » Wed Oct 28, 2009 11:58 am
Sort of like a horisontal version of the old Carter AVS / TQ secondary angled spray bars.
lluciano77
Post by lluciano77 » Wed Oct 28, 2009 10:52 pm
I see a few possible problems with these carbs;
#1- Don't let the animal rights people see those. Now they have a real reason to say your carb is big enough to suck a bird in.
#2- Anyone seen my wrench?
#3- I can already see the Holley techs getting calls about replacement 1 barrel gaskets. It is hard enough asking them info about their own carbs.
#4- Wait until someone tries to slab the throttle shaft too much, trying to get every last CFM. I'd bet money it will happen.
#5- Where is the air cleaner stud? The "bottom of the catalog" street guy with the Vortec heads is going to get a surprise after he bolts the SV1 up, and scratches his head wondering where to put the Spectre air cleaner wingnut.
#6- Does the SV1 come with a 1:1 linkage? That would be a good prank call to Pro Systems anyway.
#7- The clown that bolts one of these to a dual plane intake and wonders why his engine is down on power.
Sorry, in a sarcastic mood tonight. The carb looks cool, but probably too big for anything I am going to build. I wonder if they will make them in a streetable CFM rating. Although, I am guessing there aren't as significant results to be had on NA small blocks 500hp and under with smaller cams w/ less overlap.
Dodge Freak
Post by Dodge Freak » Wed Oct 28, 2009 11:34 pm
All great points lluciano77 8)
It does seem to favor the larger cid engines.
I laugh if they do receive a patent since it does have much in common with some very old carbs. (but then people forget)
Ericnova
Post by Ericnova » Wed Oct 28, 2009 11:40 pm
Seems like it might have come off the nearest branch on the Family Tree to the Predator carb to me, with its overhead "spray" bar.
lluciano77
Post by lluciano77 » Thu Oct 29, 2009 8:06 am
Ericnova wrote:Seems like it might have come off the nearest branch on the Family Tree to the Predator carb to me, with its overhead "spray" bar.
That is what I was thinking. It looks like a Predator carb with the adjustability of a Holley.
melsie68
Post by melsie68 » Thu Oct 29, 2009 8:28 pm
lluciano77 wrote:I see a few possible problems with these carbs;
Don't know which one of these two was funnier...! :lol: great stuff man!
1968 Camaro, tagged, insured
pump gas LS stroker 404cid
th400, 3.89 gear, drag radial, footbrake
10.110 @ 133.49, 1.455 60'
“Auto racing, bull fighting, and mountain climbing are the only real sports ... all others are games.” -E. Hemingway
T
Post by T » Thu Oct 29, 2009 9:05 pm
We will have to watch and seee what happen's. I would think that if they are that great, their will be quick change on alot of cars out there...
Those big 700+ci. guy's would luv these thing's, I would think!
P.S. There will be alot of used carbs for sale here shortly.
T
wagon train
Post by wagon train » Thu Oct 29, 2009 9:06 pm
That was my first thought.Then I was thinking man two of those bolt on a sheetmetal intake.WOW.
While wagontrain does build all his own shit in his dirty garage, he does not claim to be an expert engine builder even though his shit always stays together and runs pretty fast for being just a dumb white kid.
Troy Patterson
Post by Troy Patterson » Thu Oct 29, 2009 10:05 pm
Nice having it that short and all that cfm. Cool. Good idea.
Can't say how the fuel delivery bars will work or it's fuel delivery characteristics.
Troy Patterson TMPCarbs.net TMP Carbs
cjperformance
Post by cjperformance » Thu Oct 29, 2009 10:19 pm
I personally know some chaps here in Adelaide that were playing around with a 4 barrel version of a holley but using this same spray bar venturi system. I must get on to them, maybe they got it sorted and sold their idea! not sure. As far as I know it was working well based on 600/750 cfm 4 barrel application.
Dont know about the off idle response on a stock 302 auto! ha ha.
Should be pretty good on big ci/rpm engine!!
Craig.
