air cleaners best worst?
SchmidtMotorWorks
Re: air cleaners best worst?
Post by SchmidtMotorWorks »
This is a ducted Air Cleaner I used to make, I still have the molds but don't run them anymore (too many projects).
If anyone wants to get into the business, send me a PM.
rookie
Post by rookie »
Damn Jon, that's nice, it seems like there would be a good market for it.
Has Anything You've Done Made Your Life Better?
Post by MadBill »
These guys have a number of kits; not quite as nice as nice as Jon's, but available; http://www.ramairbox.com/
swatson454
Post by swatson454 »
MadBill wrote:These guys have a number of kits; not quite as nice as nice as Jon's, but available; http://www.ramairbox.com/
That's where I got my kit, Bill. I reckon I should've got a lower base though. I'm still unclear on that.
Live in such a way that those who know you but don't know God will come to know God because they know you.
justahoby
Location: In Stephenville, Texas, USA from Thunder Bay, Canada
Post by justahoby »
af2 wrote:Bill, I feel the one I use is pretty good. 16"
this is getting me to want to construct one.. :lol:
As I'm approaching 40,I still think I'm 20. What the hell is wrong with me?
justahoby
Post by justahoby »
SchmidtMotorWorks wrote:This is a ducted Air Cleaner I used to make, I still have the molds but don't run them anymore (too many projects).
i wish i could get into the buisiness, is a neat gig... :mrgreen:
Mpcoluv
Post by Mpcoluv »
Vintrcr wrote:Just for reference here is a factory 1969 Z/28 base. (open element-non cowl)
How tall of a filter is required with that base?
justahoby
Post by justahoby »
was thinking, on my 69 c10 i got the hood clearance for it and instead of touching the hood i could go almost the with of the engine with my housing and open it up into the opening where the wipers and hardware are, what are the pros and cons to this? i am aware i got to keep it high enough to not involve water on a rainy day, and the fact it may inconveniently hide my distributor
af2
Post by af2 »
That is where I got my base and top from.
GURU is only a name.
SchmidtMotorWorks
i wish i could get into the business, is a neat gig...
It's an OK business but it takes more time than you might think,,,ordering the parts from the molder, picking them up, assembling and boxing, then advertising, taking orders and shipping. each step is easy but put together they take a lot of time. It would only make sense for someone that knows how to retail parts.
Several mail order companies were interested in carrying them but shipping from CA was a profit drain, it would be best for someone in the mid west.
justahoby
Post by justahoby »
Used to live out west, and that was 14 years ago... Live in texas now... but remembered when i lived in Florida for awhile ordering a part from Napa that had to be shipped from California or Washington two areas of choice.. took a whopping 10 days out of washington...even 15 years ago knew of a small trucking business that went out of business in northern Cali due to the fuel costs and the big Pain in the but DOT roadside inspections became. It even scared off some of the bigger companies..
Post by F-BIRD'88 »
[/quote]
How tall of a filter is required with that base?[/quote]
use a 14x3 filter element at minimum.
The OEM holley musclecar carbs that used these GM "Z/28 L-88 L-72" filter bases all had a lower choke horn height (and downleg boosters) than the typical aftermarket version holley carb does.
So either remove the choke horn or convert-upgrade the your carb to a HP for best results.
If the PCV tube hits your carb just cut it off and block the hole.
Minor relieving trimming of the back of the air cleaner base is required to fit HEI.
Gives 1" more hood clearance than the Moroso base does.
Edelbrock carb requires a Banjo style fuel inlet fitting.
Auto choke may not fit. Edelbrock has cool little 1/2" carb 5 1/8" ring spacers that will raise the base if nessessary.
Doug Schriefer
Post by Doug Schriefer »
Bob Hollinshead wrote:
gr9082 wrote:Braswell filter is 4 to 8 HP over all filter I tested
I can't find a picture on Braswell's site, does anyone have photos of this filter assemby?
We're updating the website right now. Our filter housing uses a spun base so the air has a smooth path to travel. The top is larger than the base the filter element tapers outward, this allows you to get the full flow of the element and take full advantage of the radius of the base.
Doug Schriefer
Cris
Post by Cris »
Doug:
That looks like a nice set-up for height limited applications! Would you share some dimensions? How deep is the drop and how high does it sit above the carb mounting flange?
BTW, I presently run an L-88 drop base with a 2 3/4" K&N element and a dome lid to clear my hood. I know I'm sacrificing flow with this set-up on a 500+ HP small block.
Thanks, Cris
sc2dave
Location: Los Angeles, in The People's republic of Kalifornia
Post by sc2dave »
rfoll wrote: If I rember, it's something like 1 percent more power for every 10 degrees you reduce the temp of the air feeding the carb.
providing that you jet accordingly.
