Pondering about flathead potentials
Nikolas Ojala
Re: Pondering about flathead potentials
Post by Nikolas Ojala »
gruntguru wrote: Tue Mar 26, 2019 10:07 pmHCCI
Or SPCCI. Probably neither of those would work in a flathead. Anyway HCCI is difficult enough with DOHC, and for SPCCI you would need swirl in the combustion chamber. How is that done with a flathead?
How about PPC or RCCI then?
Anyway, if one really tried any of these in a flathead, the compression ratio should be increased tremendously. The space left for valves would be very low.
"Adding power makes you faster on the straights. Subtracting weight makes you faster everywhere."
– Colin Chapman, design engineer, inventor, and founder of Lotus Cars
Nikolas Ojala
I am still talking about the alternate combustion processes which resemble very much Diesel, and no throttle control is used.
One possibility would be SVPC (single valve per cylinder) in which there is only one poppet valve per each cylinder, opening to a nice round combustion chamber. There swirl would be possible. However there should be another low pressure valve to change gas flow between intake and exhaust. The other valve could be rotating, flapping or what ever.
Kind of extreme solution would be leaving the other valve completely out or using only a reed valve to prevent exhaust gases flowing to the intake side, then pumping excess amount of air, and using a turbocharger for that.
Nikolas Ojala
I think that the single poppet valve scheme would be easiest in a Diesel engine. Some kind of check valve or reed valve would be needed for each intake port to prevent exhaust pulses reaching intake manifold. But I think those would be all valves needed: one poppet valve and one reed valve per each cylinder. The combustion chamber would become compact and round, allowing high compression ratio.
Perhaps a unit injector could be placed in the empty space of a removed valve. On the other hand, the injector should not be placed in the exhaust port. So, I don't know would that work.
oldjohnno
Post by oldjohnno »
The Gnome Monosoupape worked with a single valve and needed no auxiliary valves. But of course it used a very short stub pipe with no manifolding, muffling or filtering. Might be tolerable with a dragster but probably not much else. Plus it doesn't allow any pressure wave/inertia tuning.
Perfectionism is the enemy of actually getting shit done.
Post by pdq67 »
Glad to see this thread back alive!
Is it possible to make a cam such that one valve can be used for both, the intake event as well as the exhaust event?
In a way, kind of like the old Jeep Tornado 6-banger SOHC engine that has one lobe for both valves...
Nikolas Ojala
pdq67 wrote: Sat Mar 30, 2019 8:05 pm
Suppose there is one high pressure poppet valve that takes care of both intake and exhaust. There should be some kind of low pressure valves below the poppet valve, completely outside of the combustion chamber. The low pressure intake valve could be a reed valve. The low pressure exhaust valve could be (for example) a slide valve or a poppet valve. Also a slide valve could work as a changer between intake and exhaust. If the low pressure exhaust valve is also a poppet valve, it could be driven by the same cam lobe as the high pressure valve, although phase must be advanced.
naukkis79
Post by naukkis79 »
Nikolas Ojala wrote: Sun Mar 31, 2019 5:49 am Suppose there is one high pressure poppet valve that takes care of both intake and exhaust. There should be some kind of low pressure valves below the poppet valve, completely outside of the combustion chamber. The low pressure intake valve could be a reed valve. The low pressure exhaust valve could be (for example) a slide valve or a poppet valve. Also a slide valve could work as a changer between intake and exhaust. If the low pressure exhaust valve is also a poppet valve, it could be driven by the same cam lobe as the high pressure valve, although phase must be advanced.
And evolution to that scheme would be two poppet valves per cylinder so intake and exhaust gases could be totally isolated until cylinder - better cylinder flush, less temperature from exhaust to intake charge, better flowing ports and so on.
Nikolas Ojala
naukkis79 wrote: Sun Mar 31, 2019 7:37 am
Except, in case of flathead, worse shaped combustion chamber. That would be acceptable as long as it is a gasoline engine with low compression ratio 8:1. But if one desires much higher compression ratio, the ordinary L-head becomes a problem.
gruntguru
Post by gruntguru »
A bit radical don't you think?
Post by pdq67 »
Instead of valves, how about injectors for all phases of combustion?
High pressure air coming in, then timed fuel injected, and finally use the piston to evacuate the exhaust..
Or would there be too much pressure drop to be practical? (In and out?)....
Just a pipe dream is all??
Brian P
Post by Brian P »
Takes work to do the compressing, whether outside the main power cylinder or within.
Pete1
Post by Pete1 »
"But if one desires much higher compression ratio, the ordinary L-head becomes a problem".
What problem? We have been running 14 to 1 on flathead Fords since the early 50's.
Kevin Johnson
Post by Kevin Johnson »
Nikolas Ojala wrote: Sun Mar 31, 2019 8:16 am Except, in case of flathead, worse shaped combustion chamber. That would be acceptable as long as it is a gasoline engine with low compression ratio 8:1. But if one desires much higher compression ratio, the ordinary L-head becomes a problem.
Pete1 wrote: Tue Apr 16, 2019 8:34 pm "But if one desires much higher compression ratio, the ordinary L-head becomes a problem".
Do you have some pictures or diagrams of 14:1 combustion chambers and pistons for a flathead Ford?
Post by pdq67 »
I want to see this also!
Pete1
Post by Pete1 »
"Do you have some pictures or diagrams of 14:1 combustion chambers and pistons for a flathead Ford?"
No pics but , flat top 2 ring gas ported pistons.
Combustion chamber looks like a smaller Edelbrock "R" head one.
