Inertial ramming as it's meant there is the recovery of the energy in the velocity of the flow as pressure. Energy is stored in the mass of the air and fuel charge, you can conserve enthalpy and convert this to pressure. This is why you'll hear pressure recovery discussed. A proper chamber design is essential to maximizing this effect.NewbVetteGuy wrote: oooOOOO! I love this thread already!
Can you define "intertial ramming" for me? I'm surprised Wave Tuning effects are listed as so low...
The the stuff about Piston dome "Creepage" it sounds like what you've said implies that a flat top piston will produce more torque than a domed piston because the flame doesn't travel as far- is this part of what you're saying?
The dome vs flat top thing is a tradeoff. Can you get an adequate C/R with a flat top? Maybe, maybe not. If you can't, then a dome will probably still win. But if you can get the adequate C/R with a flat top, it has a good chance of outperforming the dome. Imagine a flat desert, now imagine a mountain. Which is a larger distance to cross? I say creepage because that's exactly what the term is used for in electronics. The literal linear distance electricity must travel along the surface between two points. The flame front propagates through deflagration, which takes time. If you can get the mixture burning/burnt at the end of the chamber before the boundary layer has disappeared and it's heated up excessively, you win. Having the plug wayyyyy off to one side won't make that happen.
