Ported Dart pro 1 pre platinum
cgarb
Re: Ported Dart pro 1 pre platinum
Post by cgarb » Fri Oct 06, 2017 1:44 pm
Well, it was the Lunati rod's fault. That's what broke...lol.
Carnut1
Post by Carnut1 » Fri Oct 06, 2017 2:21 pm
I actually think the Wisco piston pin boss pulled out.
631-816-4911
9:00am - 9:00pm EST
Post by MadBill » Fri Oct 06, 2017 2:29 pm
2X pin boss, pending close-up pix.
Carnut1
Post by Carnut1 » Fri Oct 06, 2017 4:34 pm
The best I have. A blow up of original pic.
631-816-4911
9:00am - 9:00pm EST
BILL-C
Post by BILL-C » Fri Oct 06, 2017 4:44 pm
Do i see burned up pieces of spun rod bearing in pic?
Carlquist Competition Engines
Carnut1
Post by Carnut1 » Fri Oct 06, 2017 5:00 pm
I see some blue on the rod, I didn't disassemble post mortum.
631-816-4911
9:00am - 9:00pm EST
cgarb
Post by cgarb » Fri Oct 06, 2017 5:20 pm
Piston would have been fine if the spiroloc didn't come out the side...lol. These destruction posts are educational and entertaining at times.
BILL-C
Post by BILL-C » Fri Oct 06, 2017 5:56 pm
Usually a rod bearing gets burned up for whatever the reason and a rod bolt breaks. Then the rest of the rod and piston fall into the blender.
Scotty
Post by Scotty » Fri Oct 06, 2017 9:52 pm
To me it looks like the rod tunnel is blue. So my question is if the pin boss failed first how does this then translate to the rod bearing failure?
GARY C
Post by GARY C » Fri Oct 06, 2017 11:02 pm
I am still trying to figure out how broken parts = good head work?
user-612937456
Post by user-612937456 » Sat Oct 07, 2017 7:52 am
Good head work on someone else plaything, blue rod B's, stroked piston, all torn up, having a good time till got hurt? Sounds familiar? Hmmm..... Dont try to "figure out how" If you play the game long enough someone is bound to get hurt
user-23911
Post by user-23911 » Sat Oct 07, 2017 7:58 am
I've got one that looks just the same.
Too tight in the bore , got stuck, broke the rod.
OK so what was the question again?
A shitty build?
Carnut1
Post by Carnut1 » Sat Oct 07, 2017 8:10 am
Builder is pretty good. Not his first rodeo but getting better. Tune may have been a contributing factor. I speced the timing and he claimed it ran better with more. The compression and quench were both far from optimum. Which is most likely the reason it needed more timing. I also gave rpm shortblock limit which was ummm not followed to the letter. Not bashing by any means but a tough learning curve for him. Thanks, Charlie
631-816-4911
9:00am - 9:00pm EST
GARY C
Post by GARY C » Sat Oct 07, 2017 8:11 am
Just trying to figure out the quote under his pic on last page,"Recent R&D ( Race em and Destroy em) from a set of my heads. Way before flowbench. N.A. street stuff. Working on it M.T. Thanks, Charlie"
I always ran small cube nitrous engines from 700 to 900 horse, 7000 to 8000 rpm I just never broke anything, so is that because I didn't port my heads correctly?
user-612937456
Post by user-612937456 » Sat Oct 07, 2017 8:20 am
Sorry Gary you didn't get it. That wasn't intended as being critical of you. This post was going a little sideways so I thought I would give my contribution, my comment was just a little sexual innuendo LOL
Last edited by user-612937456 on Sat Oct 07, 2017 8:24 am, edited 2 times in total.
