BBC thoughts
prairiehotrodder
Re: BBC thoughts
Post by prairiehotrodder » Thu Oct 19, 2017 3:22 pm
I had a chance to go for a drive today. With the engine fully warmed up it was running so rich at cruise that it was off my gage. My gage starts at 10-1. Would this be what I should expect from carbs that were not calibrated for a t-ram? I changed the primary main jets from 80 to 75 on both carbs just as i put the car away for the winter. We will see next spring. I am asking these questions because i just want to know if this is typical for starting from scratch tuning a t-ram?
Brian
statsystems
Re: BBC thoughts
Post by statsystems » Thu Oct 19, 2017 4:32 pm
Brian
Now, take the carbs off for the winter and send them to either BLP or Mark Whitner and let them put a TR tune up on them. If you don't, the car will be slower, dirty and no fun to drive.
Again, I pointed out to you that cam and carb are the two biggest killers of TR performance there is. I also said you would end up spending more in the end buying off the shelf carbs than spending the money up front for the right stuff to begin with.
If you add up the time you will waste trying to sort it out yourself, plus the actual monetary output, you will easily have tripled the original costs.
prairiehotrodder
Re: BBC thoughts
Post by prairiehotrodder » Thu Oct 19, 2017 5:07 pm
sorry statsystems but i'm gonna have to disagree. Tuning and replacing jets doesn't cost much. I'm sure any carb would need a little tweaking even if it was calibrated for a t-ram. Having a t-ram is all new to me but i will figure it out and learn what it wants. The money difference between custom TR carbs and what i have was about $1000 difference. These are real nice carbs and i'm happy with them. Just have to learn what the new setup wants. I have received lots of helpful advice on speedtalk already and i'm gonna keep moving forward.
Brian
statsystems
Re: BBC thoughts
Post by statsystems » Thu Oct 19, 2017 5:55 pm
Brian
Ok.
Re: BBC thoughts
Post by F-BIRD'88 » Fri Oct 20, 2017 1:55 am
A 80 primary jet on a 750 seems big to me. I would drop the jetting to 70 pri and 76 secondary
on both carbs. What is the primary power valve channel restriction size?
At what road speed , rpm and throttle angle was it so rich?
How was it just off idle as you just get going off idle? 1200-2000 rpm ish?
Any snow there yet?
prairiehotrodder
Re: BBC thoughts
Post by prairiehotrodder » Fri Oct 20, 2017 9:30 am
this carbs came with 80 / 90 jets. Yes that does seem big to me. I'm gonna check the PVRC size and the IJ size. I tried it at a slower cruise with as little throttle as possible and about 3000 rpm, and a faster cruise of 4000 + rpm and more throttle. Both were extremely rich. With the 3.5 PV and the idle screws out about 1.25 turns i got the idle pretty decent. I have not tested WOT.
Brian
prairiehotrodder
Re: BBC thoughts
Post by prairiehotrodder » Fri Oct 20, 2017 12:30 pm
With the t-ram i understand that each barrel of a carb feeds a intake runner and intake valve. This should mean that the butterflies on the carbs open equally (not progressively) and have the jetting squared. Is this line of reasoning true?
Also - statsystems, the only part of what you said that i didn't agree with is it costing 3 times as much. I'm sure you are right and i don't doubt that you know what you are talking about. My cam may well not be optimum and dedicated t-ram carbs i'm sure would have been better. They couldn't have been worse! This time on this cam i'm gonna try what I think is best and see what the results are. Maybe i'll be disappointed but i'll show the results good or bad.
FC-Pilot
Re: BBC thoughts
Post by FC-Pilot » Fri Oct 20, 2017 1:27 pm
You may want to down size your IFR as that will make a big difference in you light cruise AFR. There is plenty more that can help, but I am not a carb guru, so you may want to search other posts and stuff.
Paul
Re: BBC thoughts
Post by F-BIRD'88 » Fri Oct 20, 2017 10:24 pm
When just sitting in the driveway and running what does the AFR gauge do if when you open the throttle from idle to raise the rpm (1200 up to 2500 rpm) part "throttle transition". ??
Is the afr in this throttle reasonable 14:1 ISH +/- or does i go pig rich 12.5:1 or richer?
or does it go lean 15:1+++ ???
Anywhere in the 15:1 to 13:1 mid afr is good..
Then when opening the throttle more to where mains fuel flow starts what does the afr gauge do?
Is this the point where it goes very rich?
Make sure the air bleeds are clear or there is nothing stuck in the emulsion wells.
Remove each air bleed and blow out with shop air.
if the primary main jet is just way too big then both throttle angle points afr will be too rich.
Swapping the primary jets to 70 should help trim both driving points.
You can do all this while running in the driveway to get it close.
I suggest 70 72 pri and 76-78 sec jets.
( if the IFR's are just too big they may need resizeing smaller but first you want to get the primary main jet roughly in the right zone)
Re: BBC thoughts
Post by F-BIRD'88 » Fri Oct 20, 2017 10:36 pm
Before installing these carbs did you flip them over and look at the throttle opening at idle to see the T-slot edge exposure or all 8 throttles? Or just bolt them on?
You want the T-slot edge exposure about .020" on all 8 barrels.
prairiehotrodder
Re: BBC thoughts
Post by prairiehotrodder » Sat Apr 28, 2018 5:09 pm
I may have to eat a little crow here, but i'm back with my tunnel ram progress. I need to get these carbs sorted out because they are way out in left field. I went for a drive today after making major tuning changes to my carbs over the winter. It wasn't good and i'm starting to think I should just ship them to somebody that knows what they are doing. Engine starts and idles fine at an acceptable AFR. Slow cruise is rich at about 10.9 and as I slowly speed up it leans out. At a fast cruise with more throttle it suddenly leans out a lot. Then at WOT its ragged and showing 12-1 AFR but I think its actually misfiring and very lean. The carbs are holley track warriors 750's. Out of the box they were really rich everywhere. I've posted over on The racingfuelsystems page my whole tuning story and what I've done. Just wanted to bring this thread back to life because i get quicker responses here usually and there are some great guys here. Thanks
Brian
prairiehotrodder
Re: BBC thoughts
Post by prairiehotrodder » Sat Apr 28, 2018 6:31 pm
ok quick update with more data.
I changed the jets in both carbs to 76/86. Stock for these carbs is 80/90. I had them at 70/80 which is what most 750 dp carbs are supposed to be at. Went for another drive
Park hot idle is 800 rpm / a bouncy 3 inches of vacuum and 12.0 AFR, need to adjust the idle screws again.
Cruise hot 3000 rpm / 14 inches of vacuum / 11.2 AFR
WOT 10.9 AFR / doesn't sound ragged anymore with the 76/86 jets. I'm not sure i trust the WOT AFR reading. I think the gage is accurate at idle and cruise but not WOT. Don't know why.
At least now i feel i can go to the track and be in the ball park. This highway tuning with a 9 second car is kinda stupid.
Brian
Re: BBC thoughts
Post by MadBill » Sat Apr 28, 2018 10:30 pm
I'm too lazy to go searching for what cam you're using, but 800 RPM seems very low for an idle speed, unless you have a very low stall speed converter...
I second F-BIRD'88 re checking the off-idle mixture. With 2 x 4 carbs, the idle circuits will be major mixture contributors up to 50 MPH or more. Open the throttles very slowly* (best via the idle speed screws), working your way up to at least 2500 RPM and see what the mixture does.(*To avoid accel pump input) If it immediately starts going rich you'll need to reduce the idle feed restrictions or increase the idle air bleeds. As a diagnosis for this condition's effect on cruise AFR, try setting the idle speed at say 1200 RPM and then lean out the mixture as much as possible without misfire, preferably 14:1 or leaner, then check the cruise mixture at a steady 45, 55 & 65 MPH.
Here's a useful idle tuning video: https://www.youtube.com/watch?v=JDPwY0LbRVY
cjperformance
Re: BBC thoughts
Post by cjperformance » Sat Apr 28, 2018 10:51 pm
^^ and to add that while doing the no load basic idle circut test its easy to remove the acel pump cams or levers to eliminate acel pump fuel. And while bringing rpm up keep an eye on the boost venturis for fuel pullover with a timing light, the strobe makes it super easy to spot fuel droplets so you will know if you are only on the idle/transfer circuit during tests.
Craig.
prairiehotrodder
Re: BBC thoughts
Post by prairiehotrodder » Sun Apr 29, 2018 9:47 pm
I warmed up the motor, removed the pump cams and slowly brought the rpm's up. At idle it was trying to go really lean and as the rpms came up it richened up. By 3000 rpm the AFR was 10.9. the funny thing is it sounded like it was struggling to come up but then it smoothed out at that rich AFR of 10.9. I had previously put smaller Idle jets in from stock .035 to .0292. I don't trust my AFR gage anymore so i'm gonna get a new one before I do anything else.
