***Post Pics of what you are working on**
cgarb
Re: ***Post Pics of what you are working on**
Post by cgarb » Mon Oct 23, 2017 9:36 pm
My 355 I'm about to sell has the tall distributor boss...maybe I should think again about selling it. It has been a very good engine to me.
Turborick
Post by Turborick » Mon Oct 23, 2017 9:46 pm
rfoll wrote:
Sun Oct 15, 2017 11:12 am
Turborick wrote:
Sun Oct 15, 2017 1:04 am
Hope to run it next week end
14567978_10211241240416662_2963183980247069396_n.jpg21761652_10214778109876188_1812262841439958557_n.jpg
Please post your results.
We set a class record of 263 miles an hour with our 256 inch turbo charge small block Chevy on gasoline this past weekend
Here is a 360° video if you’re interested in looking at the run
https://youtu.be/WJCvhoXcPDo
Rick Yacoucci
Nebulous Theorem III.V
http://www.bonnevillestreamliner.com
af2
Post by af2 » Mon Oct 23, 2017 9:58 pm
Very cool!!! Talk about coming on what sounded like 8000 and going to the moon....Nice!
GURU is only a name.
Casper393W
Post by Casper393W » Mon Oct 23, 2017 10:08 pm
I unpacked my Howard's new solid Roller for my 393w over at David Vizards tonight. This is my first Howard's roller cam and let me tell you the polishing on this cam is better than most top name brands that I have seen! Stay tuned for more details of this David Vizard spec'ed Windsor build coming up!
Andy
vortecpro
Post by vortecpro » Tue Oct 24, 2017 12:26 am
The usual.
Carnut1
Post by Carnut1 » Thu Oct 26, 2017 7:01 am
Gearing up for my next thread. Sohc counterflow port design project. DV's flowbench program will be a big help in this project. I love a challenge so this will be fun. Thanks, Charlie
631-816-4911
9:00am - 9:00pm EST
lewy-d
Post by lewy-d » Thu Oct 26, 2017 7:51 am
Charlie, are those VW heads? maybe mopar?
Carnut1
Post by Carnut1 » Thu Oct 26, 2017 8:44 am
VW Audi heads. Interesting German engineering.
631-816-4911
9:00am - 9:00pm EST
stealth
Post by stealth » Sun Oct 29, 2017 12:58 pm
2 valve a Audi head?
Carnut1
Post by Carnut1 » Sun Oct 29, 2017 1:33 pm
Yes, 80' s vintage VW, Audi 8v counterflow head. Why? Why not? Small round ports that flow pretty good stock. Valves are a good size for the bore. I don't have all the specifics nailed down. I did one intake and exhaust to see if they would respond at all and gains can be had at least flow gains. Thanks, Charlie
631-816-4911
9:00am - 9:00pm EST
user-17438
Post by user-17438 » Mon Oct 30, 2017 12:38 am
1025171947a.jpg Gearing up for my next thread. Sohc counterflow port design project. DV's flowbench program will be a big help in this project. I love a challenge so this will be fun. Thanks, Charlie
I'm not trying to discredit you or DV.. but how about you build something. Post your results, then modify it again to show your results. Vs show what a program will do. I have used pipemax to find out an engine wanted different frombwhatbwas suggested . Try things. I don't post much but nit doesn't mean I don't know much.
I can tell you there are simple formulas you can apply based on real world data, if you build and dyno/race stuff. but a dyno mule rarely wins an event. So who cares what that data is. Learn what can be done with a casring. It is what it is. That's why we have aftermarket castings. Because stock can't be modified enough.
Carnut1
Post by Carnut1 » Mon Oct 30, 2017 6:05 am
MT, stay tuned. In the works, VW Audi counterflow head and possible extension of that project, 427-440 ci Chevelle engine project, 331 chevy street mill with ported vette 128 heads, for a friend build from what I have laying around and finally getting those Dart 200's done and on a motor. Brand new ported gt40p heads that may need to be turned into cash for Christmas. Now I realize that doesn't sound like much to you pros but this is my "Passion" and not my full time gig. Last set of heads have been sent to DV for his final testing and parts selection and dyno comp between 7 sets of sbf heads coming up. Not bad for a side gig, right?
I will be using DV's porting program to help guide port size and port energy with air velocity on the VW head it should be interesting and the reason I post as much as I do I sometimes I get fantastic help from pros. Thanks, Charlie
631-816-4911
9:00am - 9:00pm EST
Steve.k
Post by Steve.k » Sat Nov 04, 2017 11:50 pm
436 ford(400 base) with chi 4v heads. Old School ur19 and a pair of 6464's. See if that livens it up.
af2
Post by af2 » Sun Nov 05, 2017 1:37 am
last yearImage at 10.00
And now at 9.50.Image
David Vizard
Post by David Vizard » Sun Nov 12, 2017 12:43 pm
I have just got involved with a build my crew chief buddy Mervyn Bonnett is doing. It is one of those mopre desirable situations which has a reletivly big budget. How about a 470 SBC build intended to run alky and nitrous?
I am currently doing the heads for this build - a set of 18 degree GM castings.
Here is where I have got to so far.
The valve train will have about 0.800 lift max rpm will be about 7500 (needs to be reliable) flow #'s at that lift are 367 intake and 258 ex (no pipe)
DV
