SBC Chinese intake
cgarb
SBC Chinese intake
Post by cgarb »
I know there was some discussion on the Holley sheet metal intakes in the past, most of it concluded that they were not worth the box they showed up in. Some said that the angled vs non angled runners would cause distribution issues which I did agree with. I ran across this one the other day, even though it isn't a dual 4 intake, as far as I could tell this is the only one that company offered. Any thoughts on this, doorstop or maybe worth trying?
kimosabi
Re: SBC Chinese intake
Post by kimosabi »
Well try it. It's cheaper right(?) and the Holley one is probably made in China too.
Where did you find this? Any guy with some metal skills can make it work.
cgarb
Post by cgarb »
eBay, search for SBC sheet metal intake and it should be there. The seller from eBay is based out of Harrisonburg VA, not too far from me. I was going to call and see if they actually had one and maybe ride over and look at one.
Post by pdq67 »
An intake like this could be used with a 3x2 carb. type top by putting the runners straight out and curved 90 degrees or so into the bottom of the plenum.
He, He!! Or with (2) Q-Jets with the front one only running with the back big barrels....
Only problem that I can see is that the runners may be too short for good midrange, "T", production?
Yes, who sells it?
Post by F-BIRD'88 »
The 2 qjets as a six barrel setup would allow to straighten out
the intake runners on a intake like this.
It would be a lot more fun too.
These intakes look to me like they will run like the old
70's era "X runner" street single planes. "StreetMaster" etc.
Someone should come up with a universal sbc intake manifold base with stub intake ports with flange so people can develope their own custom upper intake runner spider with
plenum(s), that is low cost.
Post by F-BIRD'88 »
If that thing had a removable top lid it would be more
interesting to me.
cgarb
Post by cgarb »
You could saw the top off and make 2 flanges and weld as needed...lol. Would be nice if the Chinese would copy a better design.
racear2865
Post by racear2865 »
Easily cut off with a plasma and then set up in mill and flat mill.
reed
Post by F-BIRD'88 »
If was going to get into that to make a custom intake
manifold, that intake would not be my first choice.
dwilliams
Post by dwilliams »
It reminds me of the first-generation Torker. Air didn't like going around sharp corners on that one, either.
BigBlockMopar
Momentary Specialist
Post by BigBlockMopar »
When I viewed this topic on my smartphone the other day I got the impression this was a plastic intake.
Looking at it again on a larger screen I noticed it's metal.
racear2865
Im sorry, I have to ask a stupid question, are all the comments above subjective opinions or has any one tested that intake. I guess Im lost as to all the negatism viewed here or are we just Chines disoriented. I could care less who makes a product but if it works, I want to try it--at least on my dyno. If you've tested post some numbers so me can see and me can play.
reed
Post by F-BIRD'88 »
It seems Holley has introduced a version of this manifold with removable top lids.
Post by F-BIRD'88 »
Notice in this side view that the plenum and carb location above the runners is not centered.
The carbs are pushed forward a bit. I had a similar idea for the Six Shooter 2 Qjet setup.
Post by F-BIRD'88 »
If they were to offer this in a unassembled KIT or a partial welded KIT say with the base already finished
it would be interesting. Allow you to build your own runners for it.
I'd like to see a version with the runners having a flange plate on each end so the runners bolt onto the base and bolt to the plenum bottom. This would allow the end user to experiment with runner size, length, taper shape etc.
The removable top allows for experimentation with the internal shape/volume of the plenum and runner entry shapes.
Potential as a low rise for supercharged ( blow thru or roots), or a mid rise, or a hi rise tunnel ram style.
The bolt on top allows Various carb setups or EFI configurations. Bolt on Runners could have EFI bungs
Or Nitrous bungs, ...or...
Brings sheet metal intake manifolds to the masses.
A unassembled or partial assembled KIT manifold saves production cost too.
