Novice Modified 289 Heads
Moderator: David Vizard
- Stan Weiss
Re: Novice Modified 289 Heads
The MCSA (minimum cross sectional area) is USER set able. The graphs let you move the mouse to a point and will readout the numbers for both axis. But you can also turn on moveable line that will also readout. I have a vertical and horizontal lines crossed where the MCSA fps crosses the curtain area fps.
that's neat, i like the idea of the different FPS curves for the throat, MCSA, etc the average is sometimes misleading
Digger,digger wrote: ↑Mon Jul 22, 2019 9:09 pmStan i notice you have both these which makes senseStan Weiss wrote: ↑Mon Jul 22, 2019 6:14 pm Everyone seem to have their own way they want to see the data. In my software while I don't graph all of the different ways I do try to show the data in my text report.
Code: Select all
Pressing_the_._key_will_cause_this_Page_to_be_Written_to_a_Disk_File. Bore_=_4.35_____Stroke_=_4.5_______________Rod_Length_=_6.75_____RPM_=_6500 Wrist_Pin_Offset_=_0.0_____________________Number_of_-_Intake_Valves_=_1_-_Exhaust_Valves_=_1 Intake_Valve_Size_=_2.23___________________Exhaust_Valve_Size_=_1.72 Intake_Valve_/_Bore_Ratio_=_0.512644_______Exhaust_Valve_/_Bore_Ratio_=_0.395402 Intake_Valve_Area_=_3.905707_sq._in._______Exhaust_Valve_Area_=_2.323522_sq._in. Intake_Valve_Stem_Size_=_0.3415____________Exhaust_Valve_Stem_Size_=_0.3415 Intake_Valve_Stem_Area_=_0.091595_sq._in.__Exhaust_Valve_Stem_Area_=_0.091595_sq._in. Valve_Lift_at_which_the_Valve_Area_and_Window_/_Curtain_Area_are_the_SAME_SIZE At_that_point_the_velocity_will_be_the_same_in_both_areas Intake_Valve_Lift_=_0.5575_Inches__________Exhaust_Valve_Lift_=_0.43_Inches Intake_Centerline_=_111.0__________________User_Selected_DC_-_Discharge_Coefficient_=_0.5 Throat_CSA_(0.91)_Intake_=_3.1427_sq._in.__Throat_CSA_(0.91)_Exhaust_=_1.8325_sq._in. Effective_Throat_CSA_=_0.89702_____________Effective_Throat_CSA_=_0.88808 Valve_Lift_at_which_the_Throat_Area_and_Window_/_Curtain_Area_are_the_SAME_SIZE At_that_point_the_velocity_will_be_the_same_in_both_areas Intake_Valve_Lift_=_0.44859_Inches_________Exhaust_Valve_Lift_=_0.33913_Inches Intake_Valve_Seat_Angle_=_45.0_____________Intake_Valve_Seat_Width_=_0.05 Exhaust_Valve_Seat_Angle_=_45.0____________Exhaust_Valve_Seat_Width_=_0.055 User_-_Intake_MCSA_=_3.03295_______________User_-_Exhaust_MCSA_=_1.830132 _____Intake________------_Curtain_-----___Effective__---_Throat_--____----_Valve_---____----_MCSA_---- _Lift______CFM_____fps_______DC_____Area____Area______fps_______DC______fps_______DC______fps_______DC _.2000__166.000__284.338___0.8117___1.401___1.137__126.769___0.3619__102.005___0.2912__131.357___0.3750 _.3000__227.000__259.216___0.7400___2.102___1.555__173.353___0.4949__139.488___0.3982__179.627___0.5128 _.4000__294.000__251.793___0.7188___2.802___2.014__224.519___0.6409__180.659___0.5157__232.645___0.6641 _.5000__357.000__244.599___0.6983___3.503___2.446__272.630___0.7783__219.371___0.6262__282.497___0.8064 _.6000__400.000__228.384___0.6520___4.203___2.741__305.468___0.8720__245.794___0.7017__316.524___0.9036 _.7000__426.000__208.482___0.5952___4.904___2.919__325.323___0.9287__261.771___0.7473__337.098___0.9623 _.8000__432.000__184.991___0.5281___5.605___2.960__329.905___0.9418__265.458___0.7578__341.845___0.9759 _.9000__434.000__165.198___0.4716___6.305___2.973__331.433___0.9461__266.687___0.7613__343.428___0.9804 1.0000__433.000__148.335___0.4235___7.006___2.967__330.669___0.9440__266.072___0.7596__342.637___0.9781 Avg_____352.111__219.482___0.6266___4.203___2.412__268.897___0.7676__216.367___0.6177__278.629___0.7954 _____Intake_______%_Step___--------_CFM_per_Sq._In._-------____L/D___Lift___________Sq_In _Lift______CFM__Increase___Throat____Valve__Curtain_____MCSA__Ratio___mm____M^3/s____Area____fps _.2000__166.000____________52.820___42.502__118.474___54.732__.090___5.08__0.0783___1.161__343.138 _.3000__227.000____36.75___72.230___58.120__108.006___74.845__.135___7.62__0.1071___1.841__295.950 _.4000__294.000____29.52___93.550___75.274__104.914___96.935__.179__10.16__0.1388___2.526__279.346 _.5000__357.000____21.43__113.596___91.405__101.916__117.707__.224__12.70__0.1685___3.143__272.630 _.6000__400.000____12.04__127.278__102.414___95.160__131.885__.269__15.24__0.1888___3.143__305.468 _.7000__426.000_____6.50__135.551__109.071___86.867__140.457__.314__17.78__0.2010___3.143__325.323 _.8000__432.000_____1.41__137.461__110.607___77.080__142.436__.359__20.32__0.2039___3.143__329.905 _.9000__434.000______.46__138.097__111.119___68.832__143.095__.404__22.86__0.2048___3.143__331.433 1.0000__433.000_____-.23__137.779__110.863___61.806__142.765__.448__25.40__0.2044___3.143__330.669 Avg_____352.111___________112.040___90.153___91.451__116.095 _____Exhaust_______------_Curtain_-----___Effective__---_Throat_--____----_Valve_---____----_MCSA_---- _Lift______CFM_____fps_______DC_____Area____Area______fps_______DC______fps_______DC______fps_______DC _.2000__114.000__253.167___0.7227___1.081____.781__149.303___0.4262__117.752___0.3361__149.497___0.4268 _.3000__168.000__248.726___0.7100___1.621___1.151__220.026___0.6281__173.530___0.4954__220.312___0.6289 _.4000__215.000__238.732___0.6815___2.161___1.473__281.580___0.8038__222.077___0.6340__281.947___0.8049 _.5000__238.000__211.417___0.6035___2.702___1.631__311.703___0.8898__245.834___0.7018__312.109___0.8910 _.6000__254.000__188.025___0.5368___3.242___1.740__332.658___0.9496__262.360___0.7490__333.091___0.9509 _.7000__267.000__169.413___0.4836___3.782___1.829__349.684___0.9982__275.788___0.7873__350.139___0.9995 _.8000__281.000__156.009___0.4454___4.323___1.925__368.019___1.0506__290.249___0.8286__368.498___1.0520 _.9000__285.000__140.649___0.4015___4.863___1.953__373.258___1.0655__294.381___0.8404__373.744___1.0669 1.0000__290.000__128.804___0.3677___5.404___1.987__379.806___1.0842__299.545___0.8551__380.300___1.0856 Avg_____234.667__192.771___0.5503___3.242___1.608__307.337___0.8774__242.391___0.6920__307.737___0.8785 _____Exhaust______%_Step___--------_CFM_per_Sq._In._-------____L/D___Lift _Lift______CFM__Increase___Throat____Valve__Curtain_____MCSA__Ratio___mm____M^3/s _.2000__114.000____________62.210___49.063__105.486___62.291__.116___5.08__0.0538 _.3000__168.000____47.37___91.677___72.304__103.636___91.797__.174___7.62__0.0793 _.4000__215.000____27.98__117.325___92.532___99.472__117.478__.233__10.16__0.1015 _.5000__238.000____10.70__129.876__102.431___88.090__130.045__.291__12.70__0.1123 _.6000__254.000_____6.72__138.607__109.317___78.344__138.788__.349__15.24__0.1199 _.7000__267.000_____5.12__145.702__114.912___70.589__145.891__.407__17.78__0.1260 _.8000__281.000_____5.24__153.341__120.937___65.004__153.541__.465__20.32__0.1326 _.9000__285.000_____1.42__155.524__122.659___58.604__155.726__.523__22.86__0.1345 1.0000__290.000_____1.75__158.253__124.811___53.669__158.459__.581__25.40__0.1369 Avg_____234.667___________128.057__100.996___80.321__128.224
what if you have an upstream secondary choke point that isn't the actual throat? the lift where the "choke" area starts to dictate will be somewhat lower
IOP allows to can enter whatever area you feel is significant. However an area smaller than the area presented at the valve need not be the 'choke' area. It depends on the local 'discharge coefficient' of the part of the port being questioned.
DV
Digger,
On the contrary if the relevance of the the mean port speed are understood the number produced can be compared with a proven yardstick.
I PM'ed you for your Phone # so I can fill in the details then you can explain it to the rest of the posters.
DV
i agree a choke point the straight section of the port with nice divergent and convergent shape will be less problematic than one at the start of short side that is far from ideal alreadyDavid Vizard wrote: ↑Tue Jul 23, 2019 1:15 pmDigger,digger wrote: ↑Mon Jul 22, 2019 9:09 pmStan i notice you have both these which makes senseStan Weiss wrote: ↑Mon Jul 22, 2019 6:14 pm Everyone seem to have their own way they want to see the data. In my software while I don't graph all of the different ways I do try to show the data in my text report.
Code: Select all
DV
i don't disagree that its a good yardstick in an absolute sense. but as you know things are always more complicated than they seem. i bet if you used the average based on the entire runner "size" rather than just the head port the numbers would drop as with the taper the further upstream you go the slower it is so the average speed gets pulled down because the area is pulled up. So id rather know at all of the following the average, the throat, the choke, and along points within the manifold where possible.David Vizard wrote: ↑Tue Jul 23, 2019 1:22 pmDigger,
DV
wouldn't it be easier for you to post it here to avoid the Chinese whispers?
Digger,
What are chinese whispers???
I have more to talk on than just this subject so a call would work for me.
DV
DV
you tell someone something and when they tell another persons the actual message gets distorted as they put their own spin and interpretation and then they tell another person and so on eventually the message becomes totally incorrectDavid Vizard wrote: ↑Thu Jul 25, 2019 7:25 pm Digger,
DV
Hey guys, haven't stopped work on heads yet and hope to be able to post some results or updates about them this weekend, over the past 2 weeks I've been busy, even more so after having getting sprayed in the face accidentally by some bleach by a not so aware employee at job. But I still think there are some stuff on heads that DV and i can do that will be interesting to share.
Just doing some more work on valves and getting ready to flow to see if we can get some more improvement. Will hopefully have new numbers by end of day.
Well guys we have some more information but are going to be double checking it later this month, however we do have something that you all might enjoy. The first part of the video DV and I are doing on the heads. It is now on YouTube and I'll post link in next post.
Give 'er some hips, brother
Your porting skills are progressing nicely and you're a natural in front of the camera. Those things terrify me. Well done, dude.
Good video, hips! Slows the air. Nice to see DV and some changes to the shop. Chamber shape looks good.
631-816-4911
9:00am - 9:00pm EST
631-816-4911
9:00am - 9:00pm EST
Watched the video and was curious how many CC's the combustion chamber ended up and what those modifications are worth in terms of flow?
