I think Chad gets defensive when people are telling him how wrong everyone who’s not using a 50* or steeper seat, in some particular racing series.........where there are plenty of very knowledgeable people supplying heads and engines for those competitors........ many of which are the top performers in the country.
Like none of those builders or suppliers are testing things like valve seats angles, and/or aren’t smart enough to evaluate whether or not the changes were beneficial to the combo being tested or not.
Especially......... when it would appear they’re not even familiar with the rules and restrictions that are the at the core of what those classes are about.
Up until recently, the heads in NHRA Stock and SS had to use valves and seats that retained the factory seat angles.
It’s a bit naive IMO to think that the top builders for those classes didn’t start experimenting with valve and seat angles once that rule was lifted.......... and that if steep seat angles were the be-all-end-all of additional power........ they be using them.
There are a lot of rules for these heads, especially in Stock.
Many of the heads have pretty small bowls, and no porting or blending is allowed.
Some of these combos(quite a few actually) run less than .400 lift.
Many have valve to piston clearance issues that limit how much duration will physically fit in the motor.
My experience is........ I look at any type of blanket statement like “you should run 50* seats in everything” with skepticism....... since any one way of doing things is essentially never the best approach for all situations.
But again, pretty narrow set in an even more narrow circumstance wouldn't you say?
Depends on how you look at it I guess.
It’s a pretty popular class.
Last year at Indy there were 171 cars trying for one of the 128 spots.
