About Jones Cam Designs
CamKing
Post by CamKing »
HISTORY
Since 1979, Jones Cam Designs has been the cam of choice for top engine builders in virtually every for of racing. Our unique “Parametric Profile” cam designs are part of our proprietary “Total Engine Design Equation”.
(The Brain Child of Indy-Winning Engine Designer Dick Jones). As a result of 30 years of empirical data gathered from actual dynotesting and 50 years of research and development, Mr. Jones discovered a mathematical relationship between all engine parameters. A change in any parameter (bore, stroke, rod length, etc.) will cause a direct change in engine performance due to its mathematical relationship to the other engine parameters. Mr Jones realized that as the engine parameters changed, the camshaft requirements also changed. Not just the lift and duration, but the velocity and acceleration rates change, as well as the opening and closing events.
In the late 70's, fed up with cam companies recommending the same camshaft for a variety of engines with very different parameters, Mr. Jones
designed the very first “Parametric Inverse Radius Roller Cams” which turned the standard off-the-shelf cams obsolete. Now run by Mike Jones,
Jones Cam Designs remains the industry leader, by offering the optimum cam for any engine application.
In 2004, Jones Cam Designs built their 9,000 Sq.Ft. manufacturing facility in Denver North Carolina, and expanded beyond just grinding custom cams, and now offer custom billet cam cores, tool steel valve retainers, and roller lifters.
Our Custom cam designs have powered winners in almost every form of racing you can think of. Indy Car, NASCAR, USAC Sprints, World of Outlaws, Dirt Late models, SCRA Sprints, SCOREDesert, Modifieds, SODA off-Road Series, NHRA, SCCA, USAC Midgets, APBA, and more.
http://jonescams.com/
408 Nova
Re: About Jones Cam Designs
Post by 408 Nova »
Very cool.
