Dart 180 cc alloy head as cast
Re: Dart 180 cc alloy head as cast
I like those heads they make for good acceleration and torque. But for the extra hp would the sportsman II be easier?
platinum copy 2.02 1.6 valve mistprint on sheet
Under 205cc
No pipe sf 600 4.125 bore tfwiw
297/219@.500
Under 205cc
297/219@.500
ATK built a 383 with as-cast Dart 200cc heads and HYD roller and it made 503/515hp.. Sent the heads to Eric and he ported them and put it back on the dyno and it made 515/551hp. Dyno is on youtube.
1) Your not making 540-550 with an ported head
2) Don't use my example of how to make 500+ ftlb of torque from a 3.48 stroke
Not my place to say really///copy it?////do the opposite of?///use as a stepping stone?//just noticed the cowan build was similar so l linked it. 318 cfm at only 205 volume equals high pitot readingsrandy331 wrote: ↑Thu Nov 14, 2019 5:26 pmIs this a model to copy,... Or how not to do it ??Elroy wrote: ↑Thu Nov 14, 2019 10:34 am viewtopic.php?f=1&t=58354&start=75
check this build may give you some ideas////similar cubic inch and goal///318 CFM threw 205 cc volume///something to chew on
Randy
How about a little simpler way to get that kinda power.Elroy wrote: ↑Fri Nov 15, 2019 3:41 pmNot my place to say really///copy it?////do the opposite of?///use as a stepping stone?//just noticed the cowan build was similar so l linked it. 318 cfm at only 205 volume equals high pitot readingsrandy331 wrote: ↑Thu Nov 14, 2019 5:26 pmIs this a model to copy,... Or how not to do it ??Elroy wrote: ↑Thu Nov 14, 2019 10:34 am viewtopic.php?f=1&t=58354&start=75
Randy
viewtopic.php?f=1&t=42988&p=545684#p545684
Randy
i was looking at oil ring tension yesterday
standard oil ring 16 pounds with the fish scale
i have 4'' bore oil ring that went 5 pounds drag
i want to try a vacuum pump any way when i dyno engine
with low tension rings and vac pump on the street can there be other issues.
ring pack is 1.2 , 1.5 , 3mm , piston is 417gram short skirt
Steve, is that a SHP pro series piston ?
Is it steel top with a napier second ring ?
Randy
Randy
Napier 2nd? My SN build had 4.005's in a 4.040 bore...also 3mm. It didnt smoke with no vacuum at all until it did lol.steve cowan wrote: ↑Sat Nov 16, 2019 2:32 pm i was looking at oil ring tension yesterday
Tore it apart and rehoned...put a higher tension expander in it....redynoed, still smoked. Thats when i found that the smoke was coming from my homemade intake gaskets not sealing correctly the whole time.
The shortblock was turning over at about 6 to 7lbs when I tore it down. 12 or so after putting torque plates back on , rehoning and putting a bigger expander in it.
I think you can get away with a lot less tension than what the ring people say, especially with a napier 2nd. Of course vacuum gives you some more safety.
i ordered pistons 2 months ago lol and was looking at CP with 1.2,1.2,3mm but Summit did not have to suit a 5.7'' rod so i purchased the JE piston
SRP -SP40F
top ring 4.032'' x 1.2mm carbon steel nitrate bar back cut torsional
second ring 4.035'' x 1.5mm iron -napier
oil ring 4.030'' x 3mm std tension
Chad,CGT wrote: ↑Sat Nov 16, 2019 2:55 pmNapier 2nd? My SN build had 4.005's in a 4.040 bore...also 3mm. It didnt smoke with no vacuum at all until it did lol.steve cowan wrote: ↑Sat Nov 16, 2019 2:32 pm i was looking at oil ring tension yesterday
i remember when that happened on SN,thanks for clarifying about the intake gaskets,makes me think i can make a low tension ring work in my application.
this is new territory for me hence the apprehension.
i have read there is a possibility the piston pins could get dry with vacuum in my application?? pin oilers via mains overkill??
the 4'' oil ring is a Wiseco single ring set i bought just to look at tension,it certainly feels nicer that a 16 pound oil ring
i have 4 x sets of Dart heads that i dont intend on sellingSpeierRacingHeads wrote: ↑Sat Nov 16, 2019 4:39 pm Steve, better sell your heads and buy Vortecs! Much easier!!
BUT i really like the look of the GM vortec 210 alloys
might have to get a set
I wouldnt mess with pin oiling myself. You are unlikely to be running enough vacuum for that to become an issue.steve cowan wrote: ↑Sat Nov 16, 2019 5:12 pmChad,CGT wrote: ↑Sat Nov 16, 2019 2:55 pmNapier 2nd? My SN build had 4.005's in a 4.040 bore...also 3mm. It didnt smoke with no vacuum at all until it did lol.steve cowan wrote: ↑Sat Nov 16, 2019 2:32 pm i was looking at oil ring tension yesterday
As far as expander tension. I have a new formula now. On SN I had expanders in .005 or so increments. I just went down until the piston wouldnt hold itself in the bore. Lol. Now i would get to that point...then go up .005 lol.
Just kidding lol i think your stuff is gonna do really well. Anymore i think if your shortblock is rolling over at 10 to 15lbs, youve gotten most all the meat off the bone anyway. My LS3 project i kept kind of conservative on that also. 12lbs on it if i remember correctly.
A 380" SBF dry sump road race engine I consult on runs a 2 ring low tension package with a vacuum break set to 12-14" H2O*. The consensus seems to be that that's enough to garner 90% of the potential gains without risking pin oiling problems etc. After 4 season the internals including pins look like new (*It starts to smoke under decel if it loses vacuum for any reason.)steve cowan wrote: ↑Sat Nov 16, 2019 5:12 pm...
I know some drag race apps use all they can get, 25"+...
thanks for the reply Bill,
i have read about that road race deal you are involved with ,pretty impressive.
i figured 12'' vac on a wet sump deal like i am doing would be about it.
moroso or GZ pumps not sure which way to go there.
one question i have is i am getting a re-balance of the rotating assembly,would this have to include the mandrel drive for vac pump.i do not have a vac pump set up as of yet.
