Some videos:
A walk around after start up:
[https://youtu.be/gIsZpQWs_ao
Dyno pull at full load, 1800 rpm
https://youtu.be/VbhPrj3Si5g
20th century manifold reconfigured for 21st century
Re: 20th century manifold reconfigured for 21st century
Tractor Puller, 1959 IH 460 with 430cid NA Alcohol Inline 6 started its life as a D282
The only replacement for displacement is RPM!
Update on the exhaust turning. It didn't like the small one at all down 10hp. The largest one I built was only down about 2-3hp, but looking for gains. I'm going to try the larger pipes which I don't have collects for ranging from 1-1/2 to 2".
I wanted to share my results of the split manifold test I performed. It was unsuccessful. The first attempts were to small at 1 1/8" &1 1/4", based on sound and area calculations to the 2-1/16" single. So I tried 1-1/2" 1-3/4" and just let them terminate wherever. Could never find any gains over the stock manifold at 1800rpm or 1500rpm that was my test rpm.
I did however attempt various pipes off the single pipe manifold after I seen a gain by removing the straight through muffler. The original pipe is right about 2-1/16" I attempted a 2-1/4" and finally a 2-1/2". As you can see it hated the 2-1/2" especially at the lower rpm. For clarification 450pto rpm=1500 engine rpm as 540pto rpm= 1800 engine rpm.
Its all complete and parked in the barn for the winter. Wish I could have been able to disc my field down but weather turned to fast.
