engine masters live feed?
Re: engine masters live feed?
Edelbrock perf rpm airgap ported by Geoff.
Carlquist Competition Engines
Walter do you know what heads the 289 of second place were using?im thinking the screw in stud hi perf version. Wasn't much to choose from.
[/quote]
Geoff Mummert used a set of 1965 289 base model 2v heads with a very well refined cnc porting program run on them.Steve.k wrote: ↑Tue Oct 08, 2019 2:30 pmWalter do you know what heads the 289 of second place were using?im thinking the screw in stud hi perf version. Wasn't much to choose from.Walter R. Malik wrote: ↑Mon Oct 07, 2019 11:44 am
There were no issues that anyone could see ... simply not a high enough score.
[/quote]
Any chance you helped on these Bill?
631-816-4911
9:00am - 9:00pm EST
631-816-4911
9:00am - 9:00pm EST
We gave Geoff a hand with project. He’s a real sharp guy and was able to make some improvements over our program. I think that if he didn’t have the mysterious skipping issues and was able to get in 3 good clean runs he would have won competition. He put in a real good effort on a very small budget and deserves a lot of credit for a job well done.
I have a question for competitors and that has to do with correction factor? A lot of you guys come from areas where altitude and air density would be a lot different. How close were dynos to your own testing with correction factors?
[/quote]
Using a factory 2 bolt pillow clevo block with factory cast iron heads,flat tappet cam just made an impressive 603 ft lbs and 759 hp on pump gas
[/quote]
Ah yes , stroker 351.
A 400C with offset ground crank, 4V heads and optimised for EMC rpm range could be a cool deal.
The taller deck of the 400C allowing some extra runner length would be helpfull in this rpm range.
Craig.
I haven’t had a conversation with Geoff yet on that, so, not sure.
Barry Robotnick's numbers were exact and Adney Brown's were very close.
We're at the same altitude and only 200 miles away though.
I doesn't appear to be a problem with dyno. We were playing games with some different spark plugs. The particular set we ran had 4.9k resistors, there is a possibility that the 7 box and the 2 amp coil were jumping through the porcelain to the head or something of this nature. Its a bit of a mystery right now. It would happen right at the hit when loading the motor down or it wouldn't.. This is the theory right now. We are going to run the engine and try lower power coil like we were using on the dyno at Westech. We did not experience any issues there. We did not get to test are own ignition parts there because the first box was bad. We had to get another box put it on the run stand and check polarity and timing before we put it in the crate. The truck was coming the next day.
Mummert Y-blocks
Mummert Y-blocks
I’m wondering if the msd box was mounted too close to the distributor and there was too much electronic “noise” for a clean pickup signal. I’ve run across mysterious skipping issues on dyno from pickup wires too close to coil and wires.
- John Wallace
Do you use something like 'never sieze' on the plug threads?We were playing games with some different spark plugs. The particular set we ran had 4.9k resistors, there is a possibility that the 7 box and the 2 amp coil were jumping through the porcelain to the head or something of this nature.
John Wallace
Pontiac Power RULES !
www.wallaceracing.com
yes on anti sieze, like I said before were playing spark plug games with some special adapters.
Mummert Y-blocks
Mummert Y-blocks
- John Wallace
I quit using anti-sieze because it caused a lot of ignition problems.
John Wallace
The 303" Ford Y-Block was down 24HP and 24TQ from my own dyno. Conditions were similar enough that I didn't expect a big change from one location to another. The exhaust hookup at the JE Piston facility was quite a bit different from what was tested in our shop so that will be revisited. Joe and I will have the Y back on the shop dyno and will test with a similar exhaust hookup as was used at the EMC. Ignition and fuel will also be tested as I'm typically not that far off with the numbers from one location to another. Ted Eaton.
Ted Eaton
