Valve train control loss question
curtis reed
Post by curtis reed »
I have a 23° 388 SBC that I am having a valve float issue on. Pertinent info. Cam is a Lunati #40120974 solid roller cam .404 lobes 268/276 duration 106°lsa in at 102° .022/.024 lash intake opens at 32.0 BTDC closes at 56.0 ABDC, exhaust closes at 28.0 ATDC and opens at 68.0 BBDC. Springs are K-Motion M300 dual w/damper 1.550" 669 rate installed at 1.940" 1.150" coil bind 260-265lbs on the seat 675lbs at full lift. 2.080/1.060 ss valves 11/32" stems on both but I don't know the weight of the valves themselves. Retainers are Comp tool steel 22grams ea, springs are 148grams ea and keepers are .007grams. Rockers are Yella Terra Platinum shaft rockers 1.65 on the intake and 1.55 on the exhaust. Pushrods are Trend 3/8" .080 wall straight. Lifters are Morel Sportsman Pro solid roller.
2000 lb roadster running 1.24, 3.65, 5.72 @116, 7.55, 9.18 @137 foot brake car leaving at 2200 shift at 6800, glide w/1.76, 4.88 rear. I do have data recorder with rpm, driveshaft speed, voltage, o2, vacuum, accelerometer, and fuel pressure.
It starts losing control at about 7000rpm in high gear. I assume it is the intake causing the problems. This cam states that it will work with 1.50 or 1.60 rocker ratio but I have 1.65 Any help or insight would be appreciated.
Curtis
CamKing
Re: Valve train control loss question
Post by CamKing »
That's way more spring pressure then you need for that cam.
Something else may be wrong.
A simple thing to check first, is to set the hot lash at .018", and see what happens.
curtis reed
Thanks for posting. I thought it more spring than necessary also but went with it to see if it helped. .018" on just the intakes or both?
curtis reed
Mike another question. Could being too far from coil bind cause this issue?
CamKing
Post by CamKing »
curtis reed wrote: Wed Oct 09, 2019 9:34 pm Thanks for posting. I thought it more spring than necessary also but went with it to see if it helped. .018" on just the intakes or both?
.018" on both.
CamKing
Post by CamKing »
curtis reed wrote: Thu Oct 10, 2019 8:15 am Mike another question. Could being too far from coil bind cause this issue?
Being too far from coil bind can result in spring surge, and cause issues, but that seems unlikely with this.
You've got a cam that should turn over 8,000rpm with 100lbs less nose pressure, and 40lbs less seat pressure.
curtis reed
CamKing wrote: Thu Oct 10, 2019 10:31 am
Thank you Mike. I will go back and recheck my geometry also. I have run these rockers in this configuration for years and didn't see any problems until I ran some 1/4 mile at a nostalgia event, which I don't get to do very often. I believe it showed me that I have a problem that I just wasn't hearing before shifting at 6800 and only going to 6900 at the 1/8 stripe. This cam I just started running the beginning of 2018. The rockers I set up as per Yella Terra's instructions and have a very narrow sweep that is centered pretty nice but I have never checked them with the mid lift method. Again I really appreciate your input.
CamKing
Post by CamKing »
If the problem persists, you may want to have someone "Cam-Dr" the cam, to make sure it isn't a manufacturing error on the cam.
CamKing
Post by CamKing »
I would also do yourself a favor, and switch to the Isky 9965 springs. It's much better suited for what you're doing, it''ll get your distance to coilbind where it needs to be, and the reduced pressure will reduce any valvetrain flex that could be taking place.
hoodeng
Post by hoodeng »
When you say 'it is loosing control at 7000rpm' how is it manifesting itself? is the engine plateauing or missing?
Cheers.
curtis reed
hoodeng wrote: Thu Oct 10, 2019 11:31 am When you say 'it is loosing control at 7000rpm' how is it manifesting itself? is the engine plateauing or missing?
Cheers.
It will start missing pretty bad and it stops pulling. It doesn't just lay over like an air restriction or being lean. I killed the intake springs when it did it because I was going rounds and kept racing it. LOL
hoodeng
Post by hoodeng »
Is this a new build engine or a previously proven sound engine?
Cheers.
curtis reed
hoodeng wrote: Sun Oct 13, 2019 6:42 am Is this a new build engine or a previously proven sound engine?
Cheers.
Sorry, raced all weekend and am just now getting caught back up to answer. Sort of both is the short answer.
I have run this rocker arm combination for years but in September of 2017 I broke a gear set and put in a 4.88 from a 4.56 so my finish line rpm went up then over that winter I put in the cam I listed. As I said above I don't get a chance to run 1/4 mile very often so I didn't catch on to the problem. The old cam was a CC6K lobe from Herbert. 245/255, 585/600, 106LC, 2500-6800
I already had that cam running in this engine originally with 1.60 stud mount rockers but wanted more lift so that's why I ended up getting the 1.65/1.55 combination rockers. I believe I have a problem even at engine speeds below 7000 but I just don't hear it. The race this weekend was all 1/8 and I should have run it out to get above 7000 but didn't want to chance hurting it again since I was in 2 classes. I am going to try and make a TNT before putting it away so I can try Mike's suggestion on the lash to make sure I didn't waste his time on answering me.
Curtis
hoodeng
Post by hoodeng »
You would have to go with Mike's advice.
Do you look for multiple rocker tip patterns on the valve tips when the opportunity arises?
Cheers.
curtis reed
hoodeng wrote: Tue Oct 15, 2019 10:57 am You would have to go with Mike's advice.
Cheers.
Yes I have looked it over well and it shows no signs of distress.
