HARDKORE Cam Series
CamKing
HARDKORE Cam Series
Post by CamKing »
Introducing for 2020, the HARDKORE Cam Series, by Jones Cam Designs.
The ultimate in Tool Steel cams, from semi-finished cam cores, to ready to race camshafts.
Our HARDKORE semi-finished cam cores can machined for Roller follower applications, or Flat Tappet applications(using DLC coated tappets).
Unlike other cam materials, that can only be case hardened to a max depth of .100", our HARDKORE tool steel cams are completely thru-hardened to 60hrc, so you never have to worry about grinding through the heat treat hardness again. This also allows you to regrind them as many times as you like, saving you time and money.
Our HARDKORE tool steel cams are designed with a pressed on, and pinned Distributor gear. This allows for a much tighter tolerance in concentricity between the gear and the cam centerline. On conventional "1-piece" cams, the gear is machined on the cam, before it's heat treated, where it distorts and bends, greatly effecting the gear's concentricity. Our gears can also be replaced, if they're ever damaged.
For those that don't want to run a bronze gear on their Distributor, we offer a steel gear that is compatible with our HARDKORE tool steel cams.
Available in December.
Small Block Chevy: 50mm Journals, LS Firing Order(18726543), From .380"-.525" Lobe Lift, From 240-320 Durtion@.050", From 104-118 LSA
Small Block Chevy: 55mm Journals, LS Firing Order(18726543), From .380"-.525" Lobe Lift, From 240-320 Durtion@.050", From 104-118 LSA
Big Block Chevy: Std Journals, LS Firing Order(18726543), From .380"-.525" Lobe Lift, From 240-320 Durtion@.050", From 104-118 LSA
Big Block Chevy: 50mm Journals, LS Firing Order(18726543), From .380"-.525" Lobe Lift, From 240-320 Durtion@.050", From 104-118 LSA
Big Block Chevy: 55mm Journals, LS Firing Order(18726543), From .380"-.525" Lobe Lift, From 240-320 Durtion@.050", From 104-118 LSA
Ford 351w, Ford 351c, Ford 460, and other applications will be available, later in 2020.
We can also produce custom HARDKORE tool steel cams, for any application,
If you're gonna go, Go HARDKORE !
HARDKORE logo.pdf
CamKing
Re: HARDKORE Cam Series
Post by CamKing »
BTW, we will have our HARDKORE tool steel cam cores, and finished cams on display at the PRI Trade Show, in Indianapolis.
If you're at the show, stop by and check them out.
PRI Trade Show: Dec. 12-14, 2020.
Booth# 1110 (In the main hall, across from Hilborn Fuel Injection)
CamKing
Post by CamKing »
CamKing
Post by CamKing »
CamKing
Post by CamKing »
UPDATE:
Cost to upgrade to our HARDKORE tool steel cam core, is an additional $225, over the price of standard roller cam.
Currently, we have HARDKORE tool steel cam cores available for SBC with 1.949", 50mm, and 55mm journals. BBC with 55mm journals.
In production, BBC with 50mm journals, and also our "Lightweight" LSx core that's capable of up to .525" Lobe Lift.
CamKing
Post by CamKing »
TOUGHER STRONGER BETTER-1.pdf
HARDKORE TS part#s.pdf
CamKing
Post by CamKing »
Here's a couple of pics of a 55mm, SBC, LS firing order cam, we just pulled off the grinder.
