another balance question
New pistons came in 17 gr heavier @411 gr. with rings. The old pins weighed 106 gr @ 0.787 x 2.250 x 0.200, H13. There is an H13 DLC 0.180 wall tapered pin available that weighs 91 gr. Problem solved. My questions are: a) is this enough pin and b) is 17 grams even enough to be concerned about. Total bob weight is 1356 gr, max engine speed will be 9400.
Re: another balance question
"Don't worry, be happy." The balance machine can pick up 17g, but it won't make any difference when running.
If you're concerned about the pins call the manufacturer and ask their tech guys.
A lot of engineers state that even 25 grams of unbalance is not a issue, but this it at 7000 or so rpm, at 9400 I would want far better tolerance then 17!
What engine is it ?
When Bill Jenkins was running Pro Stock with a SBC he would over balance @ 52%. I have over and under balanced 35g and more. It didn't run any better or any worse, also the bearings looked like new on tear down.
My biggest concern would be going to a heavier piston and a thinner wall pin. The weights involved in how it will balance out is secondary. I’m assuming a drag race application and 9400 RPM is at the shift/stripe. I’d talk to the piston/pin manufacturer for some possible guidance. If the current piston and pin combo looks good it may be marginal with the new stuff especially with the forces Involved at that RPM. My hunch is you’ll be ok but skimping on the pin to save weight is my last resort unless there’s a comfortable safety margin there.
I put pistons that were 45g heavier in a motor without a rebalance.
It turns 8200rpm & looks mint on pull down.
Just run it, you'll never know the difference.
My main concern would also be for the unneeded weight placing a greater load on the Rods.
This was also the opinion of the man that did the original balance. His shop serviced engines for several ARCA teams back in the day. If you compare with the total bobweight, it amounts to 1.2%KnightEngines wrote: ↑Fri Nov 08, 2019 1:28 am I put pistons that were 45g heavier in a motor without a rebalance.
Just talking in general since we strive for light weight to have a more rev happy motor.
