PipeMax v4.50 ScreenShots
PipeMax v4.50 ScreenShots :
PipeMax Professional Engine and Header Design Simulation Models :
• 2 separate Torque and HP Models converge to predict very accurate Torque and HP Data
• Header Design Model
• Filling and Emptying Model
• Intake and Exhaust System Acoustic Wave Effects Model
• Exhaust Header material Model ( with EGT temperature User input or AutoCalc options )
• Camshaft Design Specification Model
• Piston and Cylinder Head Intake Flow Demand Model each 0.5 degree of Crankshaft rotation
• Crankcase Vacuum , Oil Pan , and Oil Weight Models
• Weather Conditions and Dyno HP Correction Model ( highest accuracy Weather equations used )
• Engine Friction and Pumping Losses Model
PipeMax Professional Engine and Header Design new Features :
• PayPal purchase price is for 1 License that allows you to install PipeMax on up to 3 of your Computers
• Switch back-and-forth easily between Metric and English Units inputs
• PipeMax is programmed and compiled on latest Window's 10 version Computer
• PipeMax runs on any Window's PC from older Win-XP version up to the very latest Windows 10 version / upgrades
• PipeMax can run in 2 Modes : [1]= Predictor Style Mode or [2]= Partial Engine Simulation Mode
• AutoCalc = some inputs have optional choice to be Automatically Calculated for you ( easy User inputs )
• Professional looking Printed Data Reports for every PipeMax Window or Screen
• Easy User Interface travel thru Inputs and Choices mostly using the Keyboard Number Pad or Mouse
• Extensive Help text description for each User Input Box or Choice
• Calculates Cylinder Head Intake and Exhaust Port Flow requirements
• Calculates the effects of Port Volume and Ports CSA Velocities
• Professional Compression Ratio Calculator
• Valve Job Angles Calculator
• ET Slip -to- Engine Flywheel HP Calculator
• Nitrous Oxide HP , Blower , and Turbo inputs and their calculated effects
• Extensive amount of Fuel choices for Gasoline , Ethanol , Methanol , and Diesel Fuels
• Ability to play Flash Videos and Audio Files
• Detailed information about your Computer and its Operating System
• Professional User NotePad that you can type extensive Notes about your Engine
• PipeMax remembers the last 100 Simulation Files you accessed or saved in an easy Editor List
• Backwards compatible : will Open older PipeMax Files from version 3.70 up to 3.98
• Includes 48 example simulation Files that help you understand how to use new PipeMax version 4.50
.... so many more new Features you will need to use PipeMax to discover them !
Re: PipeMax v4.50 ScreenShots
.... ScreenShots :
... extensive Help text displayed for each InputBox and Choice :
... easily switch back-and-forth between English and Metric Units :
... 5 Screens/Pages of Calculated Data available :
... recommended Camshaft Specs as well as User's current Cam Specs
displays what each Camshaft Level should make for Peak Torque and Peak HP :
... this Screen / Page shows various Cross-Sectional Areas at various Port Velocities :
... this Screen / Page shows Intake and Exhaust Port Volume CC's , CSA's, and Port Velocities :
... this Screen shows Induction System Tuned Harmonic Lengths , Plenum Volume CC's , Entry Areas , etc . :
... Pro Compression Ratio Calculator with various available Parameters :
... Carb CFM Flow Calculator with Butterflies or Slider Blades :
... Header Primary Tube Diameters , Lengths , Harmonics Specs :
... Header Collector Tube Diameters , Lengths , Harmonics Specs :
... Valve Job Specs and Flow Conversion Calculators :
... Piston and Cylinder Head Flow Demand :
recommends FlowBench Test Pressure Range :
... Fuel - Friction Tab Screen / Page :
... Fuel - Friction Tab Screen / Page 5 Choices :
... Pro Dyno Weather Calculator :
... built-in professional looking Text Editor
where you can type extensive Simulation notes of your Engine Combination :
... Recent Files History List of the last 100 PipeMax simulation Files viewed
includes Pre-View area , which helps you remember what that File was about before you Open it :
... Multi-Media Player for viewing .FLV and .MP4 Video , along with .MP3 Music Files :
Re: PipeMax v4.70 ScreenShots
... Calculate Peak HP and ET Slip Data :
... detailed Info about your Computer , Installed Programs , and Special Folders :
... you can purchase PipeMax v4.70 program with PayPal or with your Credit Card thru PayPal
and you do not need to Join or have an account with PayPal to use your Credit Cards !
PayPal $99.00 USD Purchase Link :
https://www.paypal.com/cgi-bin/webscr?c ... Q6VFVUSSLA
Note : after you purchase PipeMax v4.70 .... come back to this page and Download + Install + Register PipeMax to receive your new UnLock Code
new PipeMax version 4.70 Download Link :
https://www.mediafire.com/file/viwxszuo ... 0.zip/file
