Race engine vs Street engine with same combo
CamKing
Re: Race engine vs Street engine with same combo
Post by CamKing »
SpeierRacingHeads wrote: Sat Nov 23, 2019 12:25 pm
CamKing wrote: Sat Nov 23, 2019 11:20 am
SpeierRacingHeads wrote: Fri Nov 22, 2019 12:57 pm Thought some might find this interesting. Maybe a discussion with some dyno results. This might not be a perfect A/B test, but the heads were the same and the components.
Basic engine:
4.165 x 3.48
Both LW Scat cranks
Both Mahle pistons
Both 6.000 rods
Same oil pans
Engine 1:
Whitener 1000hp 4150 VP113 fuel
13.50 compression
Vacuum pump w/11.2"
260/268 Solid Roller
.680 at retainers
106 LSA 102 ICL
677@7300 --- 545@5400
Calculating the efficiency of the output from engine #1, I would say you're right at the limit of that port. It can make more power with a larger cam, and more RPM, but it won't be as efficient.
YES, totally agree. Using my Leverton spreadsheet, it was using all of the cross section and flow to make that power at 7300 rpm based on 146 cfm sq/in.
Yep, when I calculated the 100% VE power for that combo @ 7,300rpm,
I came up with 683hp, and 552ft/lbs.
SpeierRacingHeads
Post by SpeierRacingHeads »
CamKing wrote: Mon Nov 25, 2019 10:37 am
Thanks Mike. Now if I could learn how to read a burette!!!
Speier Racing Heads
Chad Speier
785-623-0963
Stan Weiss
Post by Stan Weiss »
SpeierRacingHeads wrote: Sun Nov 24, 2019 1:20 pm
The vein is 2" long and .500 at it's peak on the apex. It's around 8cc.
Elroy wrote: Sun Nov 24, 2019 1:30 pm The cc of the wing is irrelevant/you have to have a good amount of area much smaller than 2.3 or its not 205//or 2.3 average/ think about it/ the average of 5,6,and 4 cant be 3./205 starting or milled flange maybe/ in the end dont matter that its much bigger/just observing trends/
If the wing is remove 205 + 8 = 213 cc's. 213 cc's @ 5.4" = 2.407 sq in AVG CSA :D
SpeierRacingHeads
This shows how big the wing actually is.. This was the master port.
Speier Racing Heads
Chad Speier
785-623-0963
SpeierRacingHeads
And as you can see, the port is really low in the casting. Floor to roof is much shorter than most heads. It's much wider than normal.
Speier Racing Heads
Chad Speier
785-623-0963
gmrocket
Post by gmrocket »
Elroy wrote: Sun Nov 24, 2019 1:50 pm
SpeierRacingHeads wrote: Sun Nov 24, 2019 1:37 pm How can the 195cc head have a 2.20 pinch and be 195cc then?
I listed the areas.
Wouldnt even try to speculate/ i would want my own measurements/thats not always cut and dry between people/ but 2.2 mi imus 195 cc from those numvers alone would suggest less major csa variations than your ports stated dimensions/ your port can be whatever you want it to be/being bigger than 205 is not a criticism so dont take it that way/only an observatiom that seem obvious by your specs/ i can be wrong if you prefer that
I know you can't respond but can see this.. so
I don't doubt the cc since its easy to to do and given 5 different people doing it, you should come up with the same
It's the min csa's that are probably off. Just the fact that the wing wasn't in the measurements in the first place tells you the min csa's are are not the minimum, in that area.
Unlike CC'ing, when it comes to measuring and calculating port csa's,, you'll get 5 different answers from 5 different people measuring the same spot..some would be way off.
6.50camaro
Post by 6.50camaro »
Corner radius has to coming into play also . You can't fiqure accurate cc's off square corner dimensions . A 1/2" radius on 4 corners will subtract about 3.5 cc per inch off port length. I dont know what Chad uses on that head but they look genrously sized . Dan
SpeierRacingHeads
gmrocket wrote: Thu Nov 28, 2019 4:26 am
I listed the areas.
The wing is nowhere near the pinch MIN CSA. The wing was deducted out of all the cross sections. The cross sections came from the actual digitized port. Maybe the software is wrong?? lol
If I have a sectional of the digitized port from start to finish, it has to be FAR more accurate than anything we do by hand.
Speier Racing Heads
Chad Speier
785-623-0963
gmrocket
Post by gmrocket »
SpeierRacingHeads wrote: Fri Nov 29, 2019 1:04 pm
I meant the csa's
Why would both those engines get the same head in the first place?
SpeierRacingHeads
gmrocket wrote: Fri Nov 29, 2019 4:39 pm
I meant the csa's
I explained that already.
And why not? I wanted one to peak at 7300 and one at 6300. Mission accomplished.
Both made great power. I don't care what anyone says. I know the dyno they were on.
Speier Racing Heads
Chad Speier
785-623-0963
gmrocket
Post by gmrocket »
Post the dyno sheet for the street engine.
SpeierRacingHeads
10.5-1, 231/235 in 108 w/112. .550 lift, 91 Octane from the SuperMarket. 7 pulls, no adjusting except 2º of timing because it's getting a elbow and TB in the car. 3.48 stroke.
Head flowed 293@.600 and 265@.600 through the induction. Carb that was used was a 750 built by Siebert.
That is manifold vacuum.
Speier Racing Heads
Chad Speier
785-623-0963
SpeierRacingHeads
Even dyno'd with the accessory belt.
Speier Racing Heads
Chad Speier
785-623-0963
SpeierRacingHeads
Here is a video on a Stuska dyno.
Speier Racing Heads
Chad Speier
785-623-0963
RevTheory
Post by RevTheory »
Sounds really good. Please let us know how it idles when you get it all wired up.
