Race engine vs Street engine with same combo
Re: Race engine vs Street engine with same combo
2.76 csa at the throat by my math/////interesting port has to be much smaller upstream to be 205cc unless intake surface milled?////most 23 heads in that arena 1206 entrance////big entrance big throat small in the middle??////or is it 205 starting CC.
good conversation to follow
2.30in² MINElroy wrote: ↑Sat Nov 23, 2019 6:34 pm 2.76 csa at the throat by my math/////interesting port has to be much smaller upstream to be 205cc unless intake surface milled?////most 23 heads in that arena 1206 entrance////big entrance big throat small in the middle??////or is it 205 starting CC.
62-68cc chamber
1.320 x 2.250 opening
Mr Gasket 5823 (trim)
2.37in² AVG CSA
5.40 port length
205cc runner*
2.08 intake w/30º BC
1.600 exhaust
This IS the port in the photo.
I think all I can do with the PR is try to make it the best possible. I had a Mondello for awhile and all my 23's were wet flowed to death,
I have a 23 degree with a 91.5% throat and a 2.150 valve. The seat is the Minimum. It's 3.00 at the pinch area. Makes great power.
The apex on the 205cc port is .900 off deck.
I have measurements every 1" at work. I will say this port is wide but not tall. Needs a .350 offset rocker.Elroy wrote: ↑Sat Nov 23, 2019 8:03 pmim not seeing your 205 visually////do you have meausrements throughout////i get the average////average makes very skinny middle at 205////correct me if my calcs are erroredSpeierRacingHeads wrote: ↑Sat Nov 23, 2019 7:49 pmI think all I can do with the PR is try to make it the best possible. I had a Mondello for awhile and all my 23's were wet flowed to death,
you have an interesting 205 23 degree to say the least////////missing input but big bell mouth on both ends interesting way to skin the cat in an extreme way////pressure losses but maybe ok in some cases... there is another 205 thread with a more conventional approach/////like said different strokes----bedtimeSpeierRacingHeads wrote: ↑Sat Nov 23, 2019 8:13 pmI have measurements every 1" at work. I will say this port is wide but not tall. Needs a .350 offset rocker.Elroy wrote: ↑Sat Nov 23, 2019 8:03 pmim not seeing your 205 visually////do you have meausrements throughout////i get the average////average makes very skinny middle at 205////correct me if my calcs are erroredSpeierRacingHeads wrote: ↑Sat Nov 23, 2019 7:49 pm
There is still more area over the apex than at the front or back. Big huge bowl, but short roof. Place a pitot dead center from front to back and it might change 10 fps all the way down.Elroy wrote: ↑Sat Nov 23, 2019 8:25 pmyou have an interesting 205 23 degree to say the least////////missing input but big bell mouth on both ends interesting way to skin the cat in an extreme way////pressure losses but maybe ok in some cases... there is another 205 thread with a more conventional approach/////like said different strokes----bedtimeSpeierRacingHeads wrote: ↑Sat Nov 23, 2019 8:13 pmI have measurements every 1" at work. I will say this port is wide but not tall. Needs a .350 offset rocker.
Mark Dalquist's 383 with a set of v2.35PF's (same head as I used). 470hp/500 ft lbs with 9.5:1 and a 215/219 cam. Less than .500 lift.
Mark dyno'd it and Scott Clark tuned it. Here is what he said. "On the engine dyno this is still the most equally balanced air and fuel per cylinder I have ever observed. And I do a lot of engine dyno projects with o2 per cyl. This engine is near perfect except for that damn lifter tick at idle lol"
that makes my visual of 205 over 5.4 even cloudier//////I will chech back in tomorrow////im not seein it//i will do more math in the morning/it dont lie if done correctly as you know/i will turn in before going on a rantSpeierRacingHeads wrote: ↑Sat Nov 23, 2019 8:31 pmThere is still more area over the apex than at the front or back. Big huge bowl, but short roof. Place a pitot dead center from front to back and it might change 10 fps all the way down.Elroy wrote: ↑Sat Nov 23, 2019 8:25 pmyou have an interesting 205 23 degree to say the least////////missing input but big bell mouth on both ends interesting way to skin the cat in an extreme way////pressure losses but maybe ok in some cases... there is another 205 thread with a more conventional approach/////like said different strokes----bedtimeSpeierRacingHeads wrote: ↑Sat Nov 23, 2019 8:13 pm
A stock 195cc ProFiler has 2.25in at the pinch and a 90% 2.08 throat.Elroy wrote: ↑Sat Nov 23, 2019 8:42 pmthat makes my visual of 205 over 5.4 even cloudier//////I will chech back in tomorrow////im not seein it//i will do more math in the morning/it dont lie if done correctly as you know/i will turn in before going on a rantSpeierRacingHeads wrote: ↑Sat Nov 23, 2019 8:31 pmThere is still more area over the apex than at the front or back. Big huge bowl, but short roof. Place a pitot dead center from front to back and it might change 10 fps all the way down.Elroy wrote: ↑Sat Nov 23, 2019 8:25 pm
My 91.5% throat with stem out is 90% as well. So it's 1.880 or 2.78in
I have two versions of it. Big Chamber (4.125 wide) and Small Chamber (4.060 wide). The small is a 2.055. The big chamber I use a 2.08 but it still has the 2.055 throat size.
- Stan Weiss
Chad,SpeierRacingHeads wrote: ↑Sat Nov 23, 2019 6:49 pm2.30in² MINElroy wrote: ↑Sat Nov 23, 2019 6:34 pm 2.76 csa at the throat by my math/////interesting port has to be much smaller upstream to be 205cc unless intake surface milled?////most 23 heads in that arena 1206 entrance////big entrance big throat small in the middle??////or is it 205 starting CC.
62-68cc chamber
2.37in² AVG CSA
5.40 port length
205cc runner*
1.600 exhaust
I get 2.317 sq in AVG CSA for a 205 cc port that is 5.40" in length
Good catch. I have two pages for the head. One for the small and big. Looks like one was 2.32 and one 2.37. I will change it!Stan Weiss wrote: ↑Sat Nov 23, 2019 10:02 pmChad,SpeierRacingHeads wrote: ↑Sat Nov 23, 2019 6:49 pm2.30in² MINElroy wrote: ↑Sat Nov 23, 2019 6:34 pm 2.76 csa at the throat by my math/////interesting port has to be much smaller upstream to be 205cc unless intake surface milled?////most 23 heads in that arena 1206 entrance////big entrance big throat small in the middle??////or is it 205 starting CC.
62-68cc chamber
2.37in² AVG CSA
5.40 port length
205cc runner*
1.600 exhaust
This head cant be anything close to 205 based on measurements given///heavily milled intake flange or 205 before porting is all that makes sense?/i have layed a few things out in different ways on paper/220 plus cc at least no matter how i figure within reason/what am i not seeing?
2.3 choke 2.3 average 2.78 throat 2.9 entry/maybe speier will clarify/
I guess I could get Darin to chime in and verify it, he used several sets on road race course engines.
How many cc's does the floor wing account for? several.
Last edited by SpeierRacingHeads on Sun Nov 24, 2019 12:26 pm, edited 1 time in total.
