Thermally stable Cast Iron
24.7 lbs
Made in USA
Purchased from lab supplier long ago.
Table usable area: 9" x 6"
Working height: 9"
Table surface has threaded holes on each side for mounting custom fixtures.
With 1" travel dial indicator
Measure piston pin height, dome height. valve relief depth, etc
Use 2 v blocks to measure piston pin or any shaft runout.
and much more.
If you need more height a longer upright can be made on the lathe.
$100.00
Urbana, IL
217-531-1770 M-F 9-5 CST
Credit/Debit cards/PP accepted
Shipping via UPS
Dial Indicator Test Stand
- Dave Koehler
- Dave Koehler
Re: Dial Indicator Test Stand
Left this out.
A 1" travel indicator is included
- Dave Koehler
Bump de Bump
- Dave Koehler
bumpy
