So I picked up this car last year and after doing some research I found out that it has a 397020 casting 307 with a 3.75 stroke crank. Kind of an oddball, but I guess it was built out of some leftovers from an Engine Masters deal around 2003. It is just a little 11 second footbrake bracket car at this point.
I have read that some of the 307's can go to a 4" bore. This sure would make pistons easy when its time to freshen this thing up. I know that it will need a sonic check to be sure.... but what is the real world experience on going 4" bore on this casting?
School me on 307 blocks
Re: School me on 307 blocks
Take it to a shop to have one Bore sonic tested if you do not get a clear cut answer here.
I CAN'T PROVE it, but I have a feeling that the later, still small journal, 283 blocks MIGHT bore to 4.030" over but I would sure sonic check it before I went that far.
I say this because of the early, small journal 302" engine. The '67 302 engine here.
I have a good .020" over '66 283 block out in my garage just for maybe another old, "Junk 301" build.
WHY ...?DeezNutz wrote: ↑Thu Jan 30, 2020 12:01 pm So I picked up this car last year and after doing some research I found out that it has a 397020 casting 307 with a 3.75 stroke crank. Kind of an oddball, but I guess it was built out of some leftovers from an Engine Masters deal around 2003. It is just a little 11 second footbrake bracket car at this point.
4" bore blocks are plentiful and ruining a 3 7/8" bore block is not the thing to do in my opinion.
If it is the engine I am thinking of, it was built by John Beck, not with just leftovers, and did quite well in that 1st contest pitting 366 maximum cube street engines.
The '67-68 small journal 302 engines weren't built by Chevrolet using overbored 283 blocks....they just dropped the 3.00" stroke crank into already 4.00" bore 327 block castings.pdq67 wrote: ↑Thu Jan 30, 2020 3:29 pm I CAN'T PROVE it, but I have a feeling that the later, still small journal, 283 blocks MIGHT bore to 4.030" over but I would sure sonic check it before I went that far.
The late production 283 blocks are less likely to successfully bore to 4.00" than some of the earlier blocks
Walter R. Malik wrote: ↑Thu Jan 30, 2020 5:30 pmThis is not "the" engine that was in the competition. I found that it was built with leftover parts from what was not used on the engine that competed.DeezNutz wrote: ↑Thu Jan 30, 2020 12:01 pm
WHY ...?
Sure its pretty easy to just transfer everything to a 350 block....this is a low buck bracket car so I am just wondering if its fact or fiction about the 307 being capable of going to a 4" bore....
Do you know?
Thanks
This is an interesting engine for sure. Do you want to share more information about the engine and the car setup ?
I dont know any real specs. I do know that it has GM fastburn heads, an edelbrock 2925 intake, and a pretty mild hydraulic roller cam have not dug into the engine at all. It runs fine on 91 octane. It came in a 73 Nova that I have slowed down to run in Summit sportsman bracket class, - 12.0 and slower, no electronics, no trans brake, no 2 steps. Pure footbrake car. TH400 and 4.10 12 bolt. Cal-tracs and QA1 single adjustable shocks
Really simple deal.
Car has run 11.60s at 115mph. I put a 600cfm dp carb on it and bolted in some weight to slow it down to 12.0xx.
