Milking the oil
Posted: Tue May 05, 2020 7:53 pm
New to the forum
I have a 555 BBC (bowtie studded block) that was in a boat that started milking the oil after I had 3 sleeves replaced. This is in an offshore boat that only was in Lake Tahoe (very cold water). The motor was fine for about 2-3 trips. When it first happened I drained around 8 gallons out of the 12 qt pan. I took it apart as I thought is was a head gasket. Nope, I put it back together with all new gaskets and it milked the next trip. This time I took it apart again and had the 088 heads pressure tested and they came back fine.
Chasing the problem I bought a set of BB2 Xtras (not a bad problem) and a new matching Brodix intake, before I heard back from the machine shop. First time out with the new heads and no milk but it had been apart awhile (I used all new gaskets each time). Next time out it milked the oil with the new heads (these 2 trips were a week apart). I ended up rebuilding it again but it did not milk the next trip and I drained the oil and pulled it out of that boat and it sat for 2 years. I pulled this motor to keep for a jet boat I was going to buy. First time out (last weekend) I drove it 3 minutes and it was puking milked oil out of every place it could. I just took it apart again and cannot find any cracks or obvious problems besides some discoloration on the cylinder walls but no rust or pitting.
My theory is the extremely cold water caused one or more of the sleeves to leak because of the oil temp and the sub 60 degree water flowing through the block. I can't explain the times it did not milk.
I am having the block magnafluxed to see if there is a crack or something I can't see. I am not planning on reusing this block and buying a new one.
I feel it is coming out of the bottom of one or more of the sleeves when pressure is present. There are no signs of water in the combustion chamber on the heads or on the top of the pistons. Also, no smoke out of the exhaust.
At this point I want to know what the issue is.
What do you think?
Sorry for the long post
What do you think?
