350/383 marine scropion cams
jred
Post by jred »
looking to see if somebody has the spec's on this cam ,, I have 1 apart for a long time and have mixed the cam up with some stock vortec rollers I can't seen to find the difference thanks for any help on this
cgarb
Re: 350/383 marine scropion cams
Post by cgarb »
Probably the cost is the difference...lol
Break
Out
Another
Thousand
bigmike
Post by bigmike »
Is there a fuel pump lobe on all the cams?
Post by F-BIRD'88 »
It is a Crane hyd roller grind.. 222/230 @.050. 112 or 114 lsa. .509in -.528"ex (approx) Made for Mercury.. A near identical cam is listed in the Crane online catalog.
You can measure the in/ex cam lobes lift using a dial caliper. Major dia minus Minor diameter of the cam lobes.
Measure and post the in/ ex cam lobe lifts.
