Long arm rockers
Long arm rockers
On intake valve would crowers long arm rocker with .090 back set the longer length to the valve make up for going to a higher ratio rocker in part at least to make it easier on a flat tappet cam ? Was thinking a lower lobe lift with as much size in the base circle and using more ratio be a better way to go on lift.
Re: Long arm rockers
Crower makes these long arm rockers from 1.5 to 1.85 im thinking id like to have 1.7 for just the intake and use 1.5 on the exhaust.
