Torque Master 90 Day Trial BBC Question
Moderator: David Vizard
skinny z
Post by skinny z »
I've had quite a bit of time to mess around with the TM program using various data points of a SBC project.
Today, I went about a BBC spec and found that the BBC hasn't been coded yet.
Is this a free trial thing or a project still in the works?
Thanks in advance.
Kevin
Stan Weiss
Re: Torque Master 90 Day Trial BBC Question
Post by Stan Weiss »
From July 2020.
Stan Weiss wrote: Thu Jul 09, 2020 11:00 am I know some of you coming in here and reading this thread are saying they added Pontiac? The answer is yes we added Pontiac because I like Pontiac. I want to thank Mike / Pastry_Chef for all of his help during the development of the Pontiac version. I am, although very slowly working on a BBC SRT version. I have no idea of any time frame when it will even be ready for someone to "BETA" test.
I have since Pulled the Pontiac stuff out of TMC and have stopped any work on the BBC stuff. Since before July 2020 David has been very busy and I have not been able to get any of his time to look at TMC.
skinny z
Post by skinny z »
Thanks for that Stan.
Well, at least the SBC stuff is functional and that's my primary area of interest.
Hopefully, it'll all come around eventually.
Thanks again.
Kevin
David Vizard
Post by David Vizard »
skinny z wrote: Sat Feb 20, 2021 1:01 pm Thanks for that Stan.
Thanks again.
Skinny,
I have been working on the BBC program for a while now but I have run into a bit of a snag. The BBC program needs a re-write of some of the SBC polynomials that work in conjustion with each other concerning multiple corrections as stroke lenght increases.This is far from as simple as it at first looks because chamber shape for any given CR ratio changes and that in turn has a effect on combustion efficiency. I have now found that my brain hemorage and subsequent emergency brain operations have deprived me of some of my math skills. bottom line is I will have to find a different method to compute the factors concerned. At present i have no ideas as to how I might do this. But I refuse to be beaten!!!
Stan Weiss
I have gotten from David provisional information for a BBC HRT version. And that has now moved into preliminary testing mode.
Post by MadBill »
Stan Weiss wrote:
> I have gotten from David provisional information...
> Stan
Is that recently Stan? David hasn't posted on S-T for two months and I was hoping his absence was due to workload rather than health issues.
Stan Weiss
> Stan
Bill,
This was during this past week. Yes he very busy.
Post by MadBill »
Thanks Stan.
digger
Post by digger »
MadBill wrote:
> > Stan
he's been doing youtube videos over last few weeks.
Post by MadBill »
Thanks Digger; I'll check them out.
Stan Weiss
Here is a new 14 Day trail version for anyone interested. It contains what David calls a "Provisional Function" for Big Block Chevy Hydraulic Roller Tappet cams and other engine parts.
PS File removed as it timed out.
RevTheory
Post by RevTheory »
I like it, Stan. Thanks for sharing.
Stan Weiss
I have been busy and have not had time to work on this. So I am just going to put it up what I have done and see what you think. Here is a new 30 Day trail version for anyone interested. It contains what I will call an "ALPHA version" for Big Block Chevy Solid Roller Tappet cams and other engine parts.
File does not work it will come up and say it is out dated.
Stan Weiss
Both David and I have been busy and have had almost no time to work on this. But for anyone that maybe interested, the Big Block Chevy Solid Roller Tappet cams and other engine parts is now in "Beta" testing.
Stan Weiss
Here is a new 14 Day trail version for anyone interested. It contains Big Block Chevy Solid Roller Tappet cams and other engine parts. This is a first release so please let know if you have any problems.
tmc_day14_6_7_0_setup.zip
Thanks,
