(Editing is difficult in this forum)
Is there a workaround to what's happening above with the ever increasing overlap?
The cam spec that's generated with 72 degrees of overlap, despite resulting in the error message is very much along the line of Torque Master.
About 288/288 with a 108 LSA on a 104 ICL. (Single pattern selected in TM). Peak HP RPM @ 6300.
Cam Master
Moderator: David Vizard
- Stan Weiss
Re: Cam Master
Kevin,skinny z wrote: ↑Sun Oct 02, 2022 1:08 pm (Editing is difficult in this forum)
TMC and CamMaster are different in how they work and that can cause differences in the cam recommended. For one thing TMC tells you what your head flow should be and CamMaster uses what your head flow is as a input.
Re: Cam Master
Thanks Stan.
I'm going to continue experimenting and see where I end up.
I'm starting to see a few cause and effect scenarios and will pursue that a little further.
Thanks again.
Thanks again.
Kevin
- firstgencamaro
Re: Cam Master
Hello, I just paid for a 1 year subscription to this site so I would be able to see and download either Cam Master or Torque master. I was able to download the Cam master zip file and install but it gives me a "Sorry but this version of the software is Out Dated". Can anyone help me out on this? Much appreciated!
- Stan Weiss
Re: Cam Master
The TMC / Torque Master Program is not available at this time.firstgencamaro wrote: ↑Sun Apr 16, 2023 12:22 am Hello, I just paid for a 1 year subscription to this site so I would be able to see and download either Cam Master or Torque master. I was able to download the Cam master zip file and install but it gives me a "Sorry but this version of the software is Out Dated". Can anyone help me out on this? Much appreciated!
The Cam Master program is something I worked on for most of 2021 and stopped at the end of October of that year for a number of different reasons. The program was never close to being a production program. I posted a couple of different versions of Cam Master here to get some feedback.
This version should not timeout for you.
Re: Cam Master
Hey Stan.
Thanks for posting that.
I've burned through my 90 day trial of TM and compiled a lot of data. Its been a useful tool when comparing the various recommendations I've solicited prior to pulling the trigger on the new cam (yes, it's imminent!).
I had a version of Cam Master as well. As I'm in holding pattern at the moment (for reasons explained elsewhere) I may experiment with CM again. There's been a few changes in the build path, most notably the CID.
Thanks again.
Thanks again.
Kevin
