E85 experimental
Posted: Wed Sep 15, 2021 1:23 pm
Likely 95% street use. 4.100" bore 3.228" stroke + 43" per cyl. Target is 65+ hp. per cyl. Hp max should be 7K + rpm. with good torque band.
Air cooled iron cylinders and aluminum liquid cooled head,( pair of cyls). I prefer reverse-flow coolant. What size(1) coolant port on exh. side ? Exh. is on bottom,
so air entrapment not likely. (2) exit, top) on intake side. Sizing between In/out ?
Thoughts ? Thanks, Art.
