Trick flow Double Hump alloy heads
Received one of these from Summit today.
Took some measurements today hopefully flow test over the weekend,these heads are going on my weekend cruiser so not going overboard.
450 hp 383 sbc,turbo 350 with 4200 9" converter 3.7:1 rear gear.
Just wanted to share some information.
The couple of things I have found so far-
Guides are tight
Pinch is very small 1.68 " CSA includes radius
Would take some work to fit 3/8" pushrods I will run 5/16"
The casting, valve job and chamber seem good,
I blued and back- blued seat and looks good.
With the 60cc chamber the 37deg top cut is very close to the deck,I want change top cut to 40deg and test.
Intake throat is 1.79" - 88% of 2.02" valve
Exhaust throat is 1.38 " - 86% of a 1.6 " valve.
Intake bowl is 1.90" - 94% of 2.02 " valve
Exhaust bowl is 1.53" - 96% of a 1.6" valve
Will put up flow numbers and velocity profile in a couple of days.
Guides are tight
Re: Trick flow Double Hump alloy heads
The Intake throat is 94%!!!
I would without hesitation step up to a 2.05" Intake valve , recut the seats to get the 45 degree Seat OD out to 2.040" and I would make use of that 1 CC or so larger Intake valve to unshroud the chamber if your not fighting for compression.
You only need 240 cfm to attain your 450 hp.
That deck finish looks great!
A quick question, a little off topic though.
How will you manage your compression ratio? I'm guessing a heavily dished piston?
Kevin
Magmag2555 wrote: ↑Fri Oct 01, 2021 6:30 am The Intake throat is 94%!!!
Throat is 88%
Bowl is 94%
Kevin
At a guess it will around 11.5:1
I personally don't have a issue with that with our 98 fuel.
My other 010 383 with my dart 182cc cast iron heads with 0.028" piston to head,64 cc chamber pumps 225 psi cranking compression
Pumpgas runs 11.10s at 120mph at 3650 pounds streeter.
Alot of guys take issue with pumpgas and a bit of compression, I dont
Picking up a new GM 350 block today.
This is a 1975 HJ Holden 4 door sedan.factory colours.
And since Holden closed its doors in 2017 a car like that is fetching up to AUD$60,000.
Interested to see what these heads do on a 383.
That little car is friggin cool. I will be watching this thread to see how your project turns out. Great work so far.steve cowan wrote: ↑Fri Oct 01, 2021 4:22 pm 20210912_083744.jpg20210912_083731.jpg20210911_182906.jpg20210907_173734.jpg
Currently a straight 6 cylinder but upgrades coming.
The two door version is also a great looking car. In my opinion, it has a better shape/style than the US GM A bodies of 1968 to ~1972.
GM Holden engineers designed some awesome cars in their day for sure
I have a feeling that head is going to port out quite nicely. Anyone know how those heads compare to AFR's Enforcer?
Steve
Be really interested in the capabilities of this casting
Would be cool if it could flow in the 290s and make 600* Hp
And be made to look original
Thanks for that Steve.steve cowan wrote: ↑Fri Oct 01, 2021 4:15 pmKevin
Your "other" 383 appears to be similar to the long (long) awaited project I'm plodding through. (On a historical note, I actually started back working on the car just yesterday so it begins...)
Do you have a thread somewhere as to what went into the other engine? (.028" PTH?)
It seems a 383 and small(ish) iron heads are part of my plan too.
I apologize if I've asked that before. It's been a long time.
Kevin
