It'll be a single bar NX plate. I thought I was being conservative. I could have been more aggressive like Eric.
AFR Eliminator Race Intake Manifold for SBC
Re: AFR Eliminator Race Intake Manifold for SBC
'73 Camaro Z/28 NETO/N
Chopper Air Port 917-589-1278
Friend just placed a ported Holley / Dorton on his SS SBC w/ Q-Jet. O2 readings immediately went to the 15.0:1 range and he couldn’t put enough jet in it to bring the O2 down. Put his SV back on and was .15 faster and normal O2 readings.SpeierRacingHeads wrote: ↑Fri Dec 03, 2021 2:06 pm IMO, the Holley Dorton 300-110 is the best SBC manifold on the planet.
The Profiler/Wilson is really good if you port it.
He’s been told by a known cylinder head guy that the Dorton needs to go on CraigsList and get an Edelbrock SV II.
Maybe the Dorton works great with a Holley over a Q-Jet?
Do you have an opinion on this?
Thanks.
NHRA SS/G
1970 AMC AMX - 390 4-speed
I'm confused, that'd be needles to enrichen the Q-jet wouldn't it ?Jeff Lee wrote: ↑Mon Apr 24, 2023 2:55 am
Thanks.
Years ago testing a Q-jet We also were super lean and took a set of sec rods out of a 301 Turbo T/A Q-jet. That got it pretty close in the A/F dept. but at the track that carb never performed right until we swapped intakes also. Took off the "new" at the time Vic Jr. and went back to the old TM-1 SBC. I have the S/V 2 now and want to test it over my 300-25 to see what the difference is also
The SV II experiment was unfortunately at a National event so that doesn’t help. But with a Q-Jet .031” rod it had 1500° range exhaust temps and he was convinced a larger jet wouldn’t fix that. So he went back to his SV intake and all was good.
NHRA SS/G
This is the 4811 with the clover leaf removed. It will be run on a 13.5:1 421 SBC with AFR 220 Eliminator heads, an IRD 1050 carb, and a 300hp NX plate...
PrettyChopperScott wrote: ↑Fri May 05, 2023 2:11 am This is the 4811 with the clover leaf removed. It will be run on a 13.5:1 421 SBC with AFR 220 Eliminator heads, an IRD 1050 carb, and a 300hp NX plate...
